As header,
I read somewhere on these forum's to disable norton auto protect when burning, cant remember the reason, but, has anyone else got any tips/tricks they swear by when burning dvd back ups.....
Thank You.
What about being connected to the net whilst burning, and say, surfing or downloading, can this cause probs..?
I've backed up a bunch of DVD's without ever defraging my drive. I only do that every couple of weeks lately if that. And before that I never did it. I've never had a bad burn caused by not defraging my drive. I think if you have some sort of burn proof or buffer underrun protection on your drive it should'nt make a difference. Without that I could see it causing problems I guess.
Your PC spec is not bad, i see no reason why you shouldnt be able to burn while doing lots of other things on the pc. Cant say about the Norton thingy, but if the burning app does a decent lock on the dvd writer it should not be a problem if the antivirus try to access the drive while its burning. I use almost only DVDdecrypter for burning and never had problems even when running encoding sessions at the same time.
tips for exporting/rendering videos to be burned to DVD's?
By johnphenomenon in forum Newbie / General discussionsReplies: 4Last Post: 23rd Nov 2010, 21:03 -
pc tips n trix
By allenstreet in forum ComputerReplies: 3Last Post: 22nd Jul 2009, 19:41 -
Steps and Tips: How to Convert DVD to iPhone on Mac
By guns1inger in forum User guidesReplies: 1Last Post: 23rd Aug 2007, 22:46 -
Tips and Tricks
By squallheart in forum Video ConversionReplies: 11Last Post: 9th May 2007, 13:50
