I just cannt seem to play these files with any success. Mainly they are either out of sync or the video is in slow motion or they freeze up or they dont play at all. I have probably installed too many codacs trying to fix it now. But anyone got any ideas?
Results 1 to 9 of 9
If your only playing video files (not encoding) I would do as suggested above.........then install FFDShow, the xvid RC4 codec (do not associate FFDShow with xvid) and a media player than can decode mpeg2 (VLC/videolan or a DVDplayer). For your audio get the AC3filter.
Question to anyone: Does FFDshow handle the latest xvid codec releases yet? -
How do I get rid of all my codacs?? I mean I can uninstall and delete them but is there a way to wip them oput of there??
Read this thread. Lots of info regarding codec packs and deleting codecs.Originally Posted by JackMartinEF"Art is making something out of nothing and selling it." - Frank Zappa
JackMartinEF, it is codec(compressor-decompressor codes). not codac
I have both the latest xvid codec and FFDSHOW installed. I have never had a problem decoding xvid with FFDSHOW. Not even with files encoded by the latest xvid build(Koepi's).Originally Posted by monzie
Odd that. Anway if anyone has problems with FFDShow not playing later xvid's try doing as I posted above (as it does work)....unless its just an oddity of my system.Originally Posted by teegee420
JackMartinEF: Glad you fixed it.
vc1 to avi problems
By happyhippo in forum Video ConversionReplies: 3Last Post: 14th Jan 2012, 14:41 -
.rm to .avi problems
By xNovaXx in forum ffmpegX general discussionReplies: 2Last Post: 21st Feb 2010, 20:54 -
AVI file problems.
By wicked_pix in forum Newbie / General discussionsReplies: 9Last Post: 5th Dec 2007, 11:27 -
.avi problems with quicktime
By Larz02 in forum MacReplies: 1Last Post: 4th Jun 2007, 15:31 -
DVD to AVI Problems
By Harvey__ in forum DVD RippingReplies: 2Last Post: 31st May 2007, 20:04
