  1. I've used several softwares to convert a VHS tape to DVD and can't get any of them to give VOB,IFO and BUP files like the DVDs have in their TS_VIDEO and TS_AUDIO folders. I end up with separate w2v and wav files or mpg.
    Can you take a VHS and produce VOB, IFO, BUP files like an original DVD?
    Software I'm trying is DVD Decryptor, DVD Shrink, TMPGEnc, WinDVD.
    Please help if you can
  2. also, when i first capture the video to HDD I have 3 choices on video format to use. MPG1, MPG2, or DVD. Which format is best to start with?
    Anyone need a stack of toasted DVD-R cheap?
  3. you will need an authoring/burning app, such as TMPGenc DVD Author or similar. Such will convert dvd compliant mpg files into what you want.
    Always check helpfiles/instructions before leaping...
  4. Member daamon's Avatar
    Melbourne, Oz
    Hi tikktokk,
    If you want freeware, check out ifoedit - as long as you don't want menu's and stuff - just straight VOBs, BUPs and IFOs.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
