  1. OK, I have a sample of a Verbatim and a Ritek GO4 Printable DVD-R, I was wondering which one produces the best quality prints and if so at what resolution.
    Also, the Taiyo Yuden DVD-R are silver tops, are they any good?
  2. Member jaxxboss's Avatar
    Apr 2003
    JAX, FL
    Print them both and decide for yourself.
    I knew a guy who married a real ugly girl , but he thought she was hot. Go figure .
  3. First and foremost, I'd see which one works best for your particular system (burner, standalone, etc.). I have a few "pretty" dvd's that don't play worth a crap.
    I've found that TY and Maxell printables burn with the same quality as their branded brethren. Ridata (printable Ritek G04's) are shakey - seem to have some QC issues. Haven't tried Verb (MCC) printables, but generally speaking, they are of high quality.
  4. The settings that I like the best are:
    White Printable - Photo Quality Glossy Film - Best Photo - 0 setting
    Silver Printable - Plain Paper - Best Photo - 0 setting
    The silver give you a holograph like look that does not work for all labels. As far as the best brand I use Ritek and I have no complaints. As for the silver I just started using Prodisc without any problems. I also let them sit for a day before playing them to allow the ink to dry. Most of the time they are dry well before that time.
  5. Member jaxxboss's Avatar
    Apr 2003
    JAX, FL
    The only 2 types I have printed with so far have been Memeorex white top (ricoh) and optodisc white tops. Both look the same, maybe the mem comes out a tad better but overall not that much of a change.
