HI
I just used dvd2svcd to convert dvd2 svcd. after converting there were 2 files 1 was 736 mb and other was 1.09 gb. now can i burn the disc 2 which is 1.09 gb to a 700mb cdr because it contains only 57 min long movie.
or else wat else can i do.
You've got something wrong in there somewhere. I used to use DVD2SVCD a lot, never any problem like that. I left all settings at default, except to enable internal ripping and setting the CD size to 800. I usually set the number of CD's to 2 max. to keep from dealing with 3 CD's. When you generate an image file and burn it with Nero in image mode, you can get about 835MB per CD, maybe a little more. 90 min CD can go higher, but not sure how much. I usually used CCE, but TMPGEnc occasionaly. Sounds like there is a problem with your settings. You might look at the Doom9 forums, they have a specific one for DVD2SVCD. I changed over to DVD's so I don't use that program anymore.
Ok, then the video is too long, not something buggy about the imagefiles. I asumed you were talking about the imagefiles when i first replied, but i guess you were not, sorry about that. You need to encode it again at lower bitrate. You can also lower the audio bitrate a little maybe.
Alternative is to split the second file, the big one, with for ex. Tmpgenc (click file - mpeg tools - merge cut), and burn it to 3 cd's.
Any suggestions to improve results?
By TBoneit in forum Video ConversionReplies: 3Last Post: 18th Jan 2011, 14:45 -
Mosaic Looking Results
By treed68 in forum DVD RippingReplies: 5Last Post: 27th Jul 2008, 04:20 -
What can I do for best picture results?
By BrokenOne in forum Newbie / General discussionsReplies: 3Last Post: 19th Apr 2008, 15:22 -
Comparing results of encoding
By nlec in forum DVD & Blu-ray RecordersReplies: 8Last Post: 3rd Jun 2007, 20:06 -
Help with Gspot Results
By Dawter in forum Newbie / General discussionsReplies: 1Last Post: 12th May 2007, 07:01
