Hi everybody,
I am new to this forum and I have a question about capturing. I've red lots of guides and learned quite some stuff, but I found no solution so far.
First, I can usually capture without problems - from TV as well as from VCR.
Now I want to capture a VHS video with some dropouts. The video is running top to bottom on these dropouts an I get dropped frames. But that's not the problem - I could live with it. The problem is that the sound capture has no dropped frames, so I get more "sound-frames" than video frames, causing the audio to play too late by time. Adjusting the framerate does not help, because the out-of-sync-problem is not linear.
Per dropout, I loose about 25 to 100 frames and there are about 6 major dropouts in the video (and several smaller ones). So the audio jumps ahead for 1 to 4 seconds per dropout.
I am using VirtualVCR for capturing - usually with good results. The "Resample Audio" option does not really help. It needs some minutes to readjust the audio after each dropout, resulting in some minutes of out-of-sync audio after each dropout.
Capturing with VirtualDub does not work for me, as I have a capture card with Brooktree chip, and can't capture in full resolution. The work-around described on the VirtualDub homepage does not work for me for unknown reasons. (Any hints here ?)
I've learned so far, that an external time-sync-box would probably solve my problems, but 200$ is definitely to expensive for me.
So, ist there any capturing software that is simply able to drop the audio frames when it needs to drop video frames - or any other software solution to my problem ?
Thanks in advance,
bluebox
P.S. No, I am not an idiot, English is just not my native language![]()
Actually, your English is much better than some of native English speaking members' posts I come across. Anyway, have you loaded any of the Conexant drivers for the BTPCI cards? My computer and Virtual Dub mod likes them just fine.
Hello. -
The capture card's brand ist hauppauge and I use up to date hauppauge drivers. I am not very eager to mess with my drivers, as they are working fine so far. VirtualVCR has no problems with the drivers, so I suppose the VirtualDub-problem sits elsewhere. But ... would the capture capabilities of VirtualDub solve my audio-sync problem ? If so, I could set up a second WinXP to experiment with the drivers.
Originally Posted by blueboxHello.
ADS Pyro A/V Link - Firmware u/g to fix VHS dropped frames
By pbanders in forum Capturing and VCRReplies: 16Last Post: 24th Mar 2011, 22:40 -
dropped frames capturing 1080i w/ Intensity Pro
By dvanoltri in forum Capturing and VCRReplies: 1Last Post: 21st May 2010, 16:10 -
Capturing nightmare. It's driving me insane. Dropped Frames only problem.
By Legit Nukes in forum Capturing and VCRReplies: 8Last Post: 27th Mar 2010, 01:34 -
Getting artifacts and dropped frames capturing DV
By CleanRich in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 1st Nov 2007, 19:54 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 20:59
