Should your capture look as good on disc as it does
when you capture it, my last capture took 21 hours to
convert with tmpge but it looked grainy, but it looked
better when i captured it, to grainy any advice.
does media player play mpeg2 files?
Results 1 to 30 of 31
We're Bought and Sold
For English Gold. -
What are you capturing (ie analog TV, video cam output, digital TV?)
And how are you capturing it? Then probably the settings you are using in Tmpeg would be benificial! -
Video tapes it is i'm capturing at 320x240 then resize it
with tmpge, the capture looks great but the convert
looks not so great.
If the clip i capture is filmed during the day it looks
ok but a night time filmed clips look grainy.
Whats the most benficial setting in tmpge that sorts
the grainyness or helps towards it.We're Bought and Sold
For English Gold. -
How much picture quality do you lose when resize clips, if
i capture at 320 240 then resize to full PAL how much is lost.
i know this should've been in the newbie section
sorry
For English Gold. -
Re-sizing upwards is best avoided as you cannot create resolution that is not there. Capture at the highest resolution that you can then convert down, or capture straight to a DVD compliant resolution. Look in "What is DVDR" for compliant PAL resolutions, there's four of them.
You'd be better to convert your present capture to 352x288 as a minimum upsizing is involved."Art is making something out of nothing and selling it." - Frank Zappa -
I'd capture in as high a resolution as your card/drivers/processor allow. 640 x 480 is more than adequate for VHS source video.
If you have installed an mpeg2 codec.Originally Posted by scotsman1"Art is making something out of nothing and selling it." - Frank Zappa
Resizing from 320x240 to 720x576, thats not good. TMPGEnc isnt very good at resizing, so you would be much better off if you captured to 352x288 and then encode it at that resolution. If you dont like to cap it again, just try to resize the 320x240 files to 352x288 when encoding it, that way you will get more bits allocated per pixel. You can get a better resize by frameserving with virtualdub and use the precice resizing there, but no miracles can be expected.
You see i'm new at this and find it so interesting
First, my capture card must me low quality to only capture
at 320x240 and i'd be better with one that can capture at
full PAL settings, this way i will get better captures and full
quality dvds, am i correct in asuming this ?
Second, if i lowers my conversion settings i will get better
quality with the card i have but with lower setting dont that
mean that i only get a small picture on screen with a large
black border?
I think if i need a better card i'm as well getting it now as i
am getting the basics and reading a lot of guides.
Thanks for all the advice, it's all noted.
For English Gold. -
Which capture card do you have? On your 2400 system even the cheapest cards should capture at greater than 320 x 240 with no dropped frames.
Q1. Yes, higher res. means higher quality.
Q2. Lower res. does not mean a smaller picture on your TV. The picture will display at the same size."Art is making something out of nothing and selling it." - Frank Zappa -
It's a Wintv 878/9 card, when i capture above 320x240 the picture
freezes on start of capture, it still captures but the pic on virtualdub
freezes, i dont know if this is of any significance i also loss some frames.
I tried capturing at full PAL settings but the pic wasn't so good, maybe
i'll try lowering it, but sure the screen pic.
Zippy do you mean i'll get a pic the size of the capture, 320x240,
very samll or am i picking you up wrong.
Thanks again for all the help.
any full capture cards for about £50We're Bought and Sold
For English Gold. -
Sorry I can't help with your capture problems...not my area of knowledge.Originally Posted by scotsman1
The picture may well display on your PC screen in the size of your capture (ie 320x240) but then you can always resize the window to fit.
As for your TV, it doesn't matter which DVD resolution you choose as your DVD player will resize it to fill up your screen. What I'm saying is that 720x480 or 352x240 will still be the same size on your TV.
As for wide screen or full screen, I didn't want to mention them but here goes....16:9 or 4:3 are display aspect ratios and they control how the picture is displayed, not the resolution of the video.
Choose Full Screen (keep aspect ratio) to fill the screen and preserve the original display type."Art is making something out of nothing and selling it." - Frank Zappa -
Ok - so it's a PCI card.It's a Wintv 878/9 card, when i capture above 320x240 the picture
Try using VirtualVCR.
I had problems with VirtualDub. It wouldn't capture above 352 for me. You should be able to go above that with VirtualVCR.
As for your lost frames. Make sure you defragment the drive you capture to and switch off as many Windows apps/services as possible. Even disconnect from the net whilst you capture. -
Theres one thing you can do if this captures are not so critical, a method i used myself with 320x240 clips filmed with digital still picture cam in MJPEG format. This clips are not important, just for fun, like small party movies with friends and so on, i encode it to PAL with add borders, 24 at top and bottom, 16 at each side, then the video will keep its aspect ratio quite well when played on tv and i dont lose picture quality in resize. This does not work when converting to NTSC, then the aspect ratio is totally gone, so resize it in taht case.
The AviSynth script i use for this(the videos only 15fps):
AviSource("myfile.avi",False)
ConvertFPS(25)
Addborders(16,24,16,24)
In TMPGEnc you can do it by simply setting Video Arrange Method (under the advanced tab) to Center. -
Works very well @ full PAL resolution using the drivers available at http://btwincap.sourceforge.net/. You must turn overlay mode off in virtual dub when switching to over 288 lines resolutions (use preview mode or capture without preview).It's a Wintv 878/9 card
Other recommendations: use YUV2 colorspace and PicVideo MJPEG codec at quality setting 19/20. Encode your video as interlaced. -
This is what I have been using. AVI_IO and set resolution to 640 x 480, either RGB24 or YUV2 and video as uncompress. Before that, install Picvideo MJPEC codec and set capture quality to 19.
Please read this capture article at arcstechnica. It will save a lot time.
http://arstechnica.com/guide/audio-visual/videocapturing/vidcap-1.html -
I splashed out and bought a Pinnacle PCTV card that
will capture at full PAL, does the Pinnacle work well
with virtualdub?
I've got it in and working just some fine tuning to do, all
the advice has been taken in.
For English Gold. -
Isn't Pinnacle PCTV also based on Bt 879 chip? It is also listed on Btwincap supported cards list.
You've lost me there man, does Pinnacle capture direct
to mpeg2, am i correct in asuming this ?
Is pinnacles software worth using or should i be using
something else, is there any point in using virtualdub?
i tried it but it but it said the capture driver was missing.
I tried pinnacles software for capturing but the sound and
pic settings were out.
any tips what route i should take with this cardWe're Bought and Sold
For English Gold. -
What is it with this card, i've had it 3 days and captured
nothing of any value, after learning the basics with a
wintv card i feel wasted.
Virtualdub says theres a problem with the capture driver,
pinnacles capture cant keep the music in time.
I downloaded BTwincap and installed it but in my device
manager i see an exclamation mark at it, how do i make this my
new capture driver?We're Bought and Sold
For English Gold. -
Don't use VirtualDub to capture.
Use VirtualVCR.
It will permit higher resolutions. -
Sorry to be such a nerd but my problems continue…I took my pinnacle back got a £50 refund and then spent another £60 on a WINTV-250. every time I try and set up a capture it says—failed to initialise capture driver another programme must be using it but no other programme is on, that’s with the software the comes with the card. When I try it on virtualdub is says the same thing, with virtual vcr I get a windows error warning.
This also happened with the pinnacle but I took that back because of the reviews, I know I should have read them first.
I’ve tried uninstalling the driver downloading the latest one and it still happens.
The tv card works a treat great picture but when I put a vhs video on its at least 5 seconds out of sync, that’s just with a tape playing no capture, the pinnacle did this to so I suspect it’s a pc setting that’s causing it because it was reviewd well and loss of sync was not mentioned.
well I been here 6 hours trying to get this and I’m off to bed now
all help greatly appreciated.We're Bought and Sold
For English Gold. -
You might want to try putting it in a different PCI slot. Sometimes that helps. It may be sharing an IRQ with another device in the slot it's in now. You can find that information in "Control Panel, Performance and Maintenance, System, Hardware, Device Manager" then click "View, Resources by Type" then double-click "Interrupt Request (IRQ)" then find your capture cards IRQ number and see if it's also being used by any other device. Moving it to another slot will sometimes change the IRQ it will be assigned. Could be whats going on.(?)
Good luck. -
[/quote]I put a vhs video on its at least 5 seconds out of sync, that’s just with a tape playing no capture
What do you mean by "out of Sync".
There is always a slight delay going through a capture card due to the MPEG encoding.
Just a few hints. Are you running an anti-virus program? Turn it off when doing any video work. Close all unnecessary services. See www.blackviper.com for procedures to turn off these services. Run AD-AWare or Syp-Bot to clean any spy ware off your system. In other words remove any processes or applications that will use any processor cycles.
The Hauppauge is a very good card. -
Make sure you've uninstalled the btwincap drivers and install the drivers that come with your new capture card.
The latest Hauppauge drivers should permit resolutions above 352.
Just out of interest, which graphics card do you have? -
Its only a 64mb ATI graphics card, everything worked ok
up untill i upgraded my card, pic was good everything was
in sync then i upgrade and bang everything goes skyward.
I'll get a way around it and today as soon as i finish work
i'll change the slot ans see if it makes a difference.We're Bought and Sold
For English Gold. -
Try out this link:
http://www.shspvr.com/
This website is dedicated to the Hauppauge WinTV-PVR capture cards including the 250 model.
There is a lot of information there including tips and "tricks" on getting everything to work correctly.
I put the capture card in another slot and even ended up
giving my pc a full format but it still refuses to play in sync
or even recognise the capture drive.
I'm trying something from wintvs home page and downloaded
the first part to the correct folder but cant find the folder for
the second part to down load, could some point me in the right
direction to the win\inf folder.
Download these 2 files, and save the Hcwncusb.sys into the system32/drivers folder, and the Hcwncusb.inf file into the c:\windows\inf folder, and reinstall the drivers and application software. If the same problem continues, search for and delete the Ivivideo.ax and Iviaudio.ax files from the system and repeat the installation procedureWe're Bought and Sold
For English Gold.
DV capture quality sucks
By cooldude859 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 36Last Post: 28th May 2008, 16:07 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 19:05 -
Problems with Capture Quality
By drxpsp9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 25th Jul 2007, 23:53 -
How To Capture in better quality Help??
By Force21 in forum Newbie / General discussionsReplies: 1Last Post: 27th Jun 2007, 17:46 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 20:42
