I got some TV programs recorded in SVCD format. I just found out that all audio is messed up with no signal at all from the right channel although it is still recognized as stereo.
The best thing I can think of reparing is to copy the left channel data into the right so that at least the sound will be balanced.
I know I can easily do the copy in a sound editor such as cooledit pro. But I want to know if there's a way to copy the channel in native mpeg2 audio format. I don't want to re-encode anything if possible. So if I can de-mux the clip, fix the audo in mpa format, the re-mux the audio back with the orig video, that's a good solution.
Can anyone tell how and/or what program to use to do this channel copy in mpeg2 audio natively without re-encoing?
Thanks a lot!
Eric
I'm pretty sure re-encoding is a must considering that you will be adding a channel in place of dead silence. I've done things like this and I wasn't able to notice any loss.
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 7Last Post: 21st Oct 2015, 12:32 -
-acodec copy to 6 channel audio results in 2 channel?
By ninethirty in forum Video ConversionReplies: 1Last Post: 11th Feb 2011, 12:54 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 22:46 -
Sound on both channel fix possible on mpg and wmv?
By Blå_Mocka in forum AudioReplies: 2Last Post: 3rd Jul 2008, 15:25 -
Convert single channel to double channel audio ...
By tariq_niazi in forum AudioReplies: 3Last Post: 15th Nov 2007, 17:47
