hey everyone, Im sill kinda new to torrents / burning etc, I wouldnt really consider myself a beginner, but more of a good novice user or so
anyhow, I'd be greatful , if anyone could shed some light to my problem
Ok, Ive got a prob,with media players. so 1st ler me list what systems I have ,
Divx Player
Video lan player [VLC]
Win DVD
windows media 9
an i know most of the time, when someone has video/audio/media paler problem, everyone wants to yell ''codecs''
well, Ive check ed my codecs situation an all seems to be inline,,
an once I explain my problem, i think [well I Hope]
someone may understand , an know my solution,
Ok, ive got a dvd-rom/r-rw drive, an a cd-r/rw rom,
an Ive also got alot of movie files, tv eps, etc.
1 ST,,
well these files , an or dvd's will play with Vlc, an windows media player
an they play just fine,,,
but when I insert a dvd in my pC's dvd-rom,
an when the WinDVD menu comes up ,, I dont get the menu or anything like that ,,
it says,,
''CREATE OVERLAY FAILED , PLEASE ADJUST YOUR SCREEN RESOLUTION OR COLOR DEPTH , AN TRY AGAIN''
an I could understand if it were codecs , but even reatil dvd's wont play, thru win-dvd... but like I said ,, will, play thru VLC-or WMPlayer..
2nd, Now when I try to open a file w/ Divx player,
I get the following messages/ an it seems random,,
sometimes it'll say
'OPEN FILE FAILURE ;
THIS FILE CANNOT BE OPENED;
UNKNOWN EXCEPTION CAUGHT''
OR something about DirectX , i cant recall the actual word for word phrase.
So Ive went an un-installed win-dvd & divx, an also checked all my codecs'
I also went thru Gspot , just to be sure,,
an another thing that makes me think it's NOT a codec problem , an thats
because NO files or dvd's will play AT ALL!! ON EITHER PLAYER!,
BUT W/ VLC & WMP9 I CAN PLAY TYHE STUFF ALL DAY, ANY KIND OF FILE OR DVD,
an back when I first got into getting movies an stuff via the net, an watch on my PC , or to burn to cd-r or dvd-r, I had alot of probs outta my codecs,
an some files wouldnt play , but others would,
an this was for all the players I mentioned , [divx,wmp9,vlc,windvd]
Like it would play an Mpeg, but Not Avi, an stuff like that
So I went thru alot of stress over codecs for like 2weeks, but the good thing about that, is that I ended up learning all about codecs,
so thats why I dont think this has to do w/ codecs,
an if nothing else I should be able to watch a retail dvd on my pc, thru windvd,
cause thats the software disc that came w/ my dvd-rom,
So in a Summary,, any advice,
What should I do, where should , I look?
whats' up w. the screen reso, & color depth?
an if it is something to do w/ directX then how should i go about it?
I think most of my directX stuff was installed like thru PC games, an stuff,
I dont know much about directX,,
Is it possible Ive accidentail deleted some kinda DLL or something that
win dvd & divx player would require?
any advice or insight to this would be nice, an I'd be greatful,,
PS , an since posting this, ive checked my screen reolution & my color depth , an still no effect,
Bare with me please,,brain cellz not functioning at normal capacity!!
Common DivX DVD Players AVI Playback problems!
By Baldrick in forum Newbie / General discussionsReplies: 8Last Post: 6th Jun 2013, 10:32 -
Best audio settings for MP4 on Win Media Center & Mobile Players?
By thefiddler in forum Video ConversionReplies: 8Last Post: 14th Aug 2010, 07:58 -
Problems ffdshow codec & Media Center 2005
By Miss Sherlock in forum Newbie / General discussionsReplies: 0Last Post: 14th Sep 2009, 23:28 -
MPEG-4 (DivX & XviD) movie discs no longer recognised by players.
By Sproggins in forum Newbie / General discussionsReplies: 11Last Post: 6th Sep 2009, 16:09 -
Toshiba DVD players & -R media issues??
By videobruce in forum DVD & Blu-ray PlayersReplies: 8Last Post: 5th Nov 2007, 07:02
