Hi All !
Just wondering if it would be ok to have both an ati all in wonder 9000 pro and an ati tv wonder pci both installed and running on the same computer. My graphics card is a nvidia and the fan is extremely noisy. I want to use the 9000 as a graphics card, because of my "macrovision" issue ! And use the ati tv wonder pci as the capture card!
thanks
I'll give it a shot.
Having two similar cards, the problem I see is the drivers interfering. If you had the cards, I would try it, but if you are looking at buying them, you may want to research further. You could check the ATI site to see if what drivers they use and if they have any FAQ's that might cover the subject. Also, why not change the Nvida fan to something quieter? -
I have both the ati aiw 9000 pro and the ati tv wonder pci in my possession. But currently installed on my system i have the ati tv wonder pci and the nvidia geforce2 installed. I'd like to replace the noisy nvidia graphics card with my ati aiw 9000 pro, but use the ati tv wonder pci for capture because of my "macrovision" problem.
Capture card quality question
By Hackerpcs in forum Capturing and VCRReplies: 22Last Post: 18th Nov 2010, 16:41 -
Question about difference between direct capture and sound card recording
By jimdagys in forum AudioReplies: 3Last Post: 16th Sep 2009, 09:09 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 10:45 -
Question about software for K-World Video Capture Card
By cooper101 in forum Newbie / General discussionsReplies: 10Last Post: 31st Oct 2007, 13:49 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
