Hello All
I have a VCD with a Dat file in it. The file plays very slowly, like the movement of actors and actresses does not seem normal, it is slow and jerky. There is no problem with cd, just that the DAT file is playing slowly than it should.
Looks like when the file was ripped, it was ripped with some parameter being wrong.
I can rip it again in virtual dub but don't know which parameter to change to see if the Dat file can be repaired.
can someone please advise?
Hi teegee420
I think you did not understand the question. I do not have any problem with the cd itself. ISOBuster is used to extract fiels from a damaged cd but I dont think it can rip a dat file.
My problem is that the dat file plays slowly than it should. This is true whether I play from a cd player or a hard drive. Its the dat file that needs to be re ripped again but I dont which parameter to change to speed it up.
try rip it to a mpg with isobuster, removing the mode2 headers,
https://www.videohelp.com/guides.php?link=95 -
I tried but unfortunately it did not work. Extracting with the mode2 headers filter results in a 0 MB file. I guess I will have to scrap this vcd.
Thanks for your help folks
Speed up Virtualdub
By graphics in forum Newbie / General discussionsReplies: 6Last Post: 24th Jul 2011, 20:13 -
How do I speed up my video to 10X speed?
By mileena in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2010, 14:24 -
Internet speed
By Jomapil in forum ComputerReplies: 5Last Post: 8th Jan 2010, 10:00 -
Speed of RAM
By Seeker47 in forum ComputerReplies: 14Last Post: 5th Dec 2008, 00:07 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 03:41
