I have just switched from my old trusted 8mm to miniDV format, been toying around with capturing, other than the usual newbie problems, things are satisfactory. One thing that I like to know is if there is a way to just PLAY my DV (from my digicam thru firewire) on my WinXP PC without using any capturing software.
I will be travelling with my laptop (firewire equipped) with my miniDV and like to be able to look at the video on the laptop, so far, I've tried using Windows Meda Player, but it does not appear to recognize firewire as input source. If some cheap software solution exist, I'll be happy to pay for it, as I do not want to carry all the overhead of my current capture software (Ulead VS, MyDVD Deluxe, PowerProducer..). Thanks.
Use Windows Movie maker. In the capture screen, you can just play the video by controlling the camera through your PC. It's used to cue the tape to the proper place before beginning capturing. Might be limited in terms of video window size though.
Hi, thanks for the quick replies. I did try Windows Movie Maker, it's a bit bulky, and the screen is way too busy, video window also too small. WinDV looks like the ticket, just downloaded it, unzip, start, plugged my MiniDV into firewire, and off it goes. The only thing I am not getting is audio, tried both audio format on config, but no luck, is there a trick to this ?? Thanks a bunch.
What you need is a little program called TV Viewer 3.0.
You can download it here: http://www.aptrio.com/Multimedia/Video/tv-viewer-download-451.html
It allows you to view footage from a DV cam at fullscreen and with sound.
IEEE 1394 card
By beavereater in forum ComputerReplies: 1Last Post: 21st Jun 2011, 05:28 -
Looking for a minidv with 1394, external mic...
By Haopengyou in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th Apr 2011, 17:16 -
IEEE 1394/MS DV ERROR
By sampatman in forum Capturing and VCRReplies: 1Last Post: 12th Feb 2010, 11:54 -
Best Practice with ADVC-1394
By kjfrey55 in forum Capturing and VCRReplies: 1Last Post: 12th Feb 2010, 02:15 -
DV 1394 connection
By Gravez in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 9th Jun 2008, 12:57
