Hello,
I am using snowmoons excellent avs script to speed up a Divx AVI to 25 fps, using the following lines:
AVISource("test.avi")
ResampleAudio(44100)
assumeFPS(25, sync_audio=true)
bilinearresize(480,432).addborders(0,72,0,72)
The source DivX has 48kHz stereo (encoded with MP3), has 23.976 frames/second, and a dimension of 640x384.
If I open the resulting .avs in Virtual Dub, it gives me 25fps, but the audio part is messed up, showing mono (one channel) with 45983 Hz...
I guess this value is due to the speed up of the video, so what can I do in order to get a 44.1 kHz audio stream? I wanted to use this method to avoid having to extract, pitch and convert the audio with CoolEdit, can anybody help me with this?
Another option would be AviFrate to change the frame rate in the DivX header to 25, but I wonder if AviFrate also changes the audio speed to match the increase playback in video.
Comments?
Thanks a lot in advance
I don't think you want to do anything with the audio after you'ved use AviFrate. Personally, I've never tried AVISynth to do 24->25 fps conversion. I know cooledit takes a while to downsample and convert, bet you get a first-class result when you're done.
AC3 audio: 25 to 23.976 fps
By leghorn in forum AudioReplies: 7Last Post: 14th Mar 2012, 02:36 -
To synchronize 29,970 audio fps for 23.976 fps
By DruidCtba in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2009, 13:01 -
How to stretch a DTS audio file from 23.976 to 25.000 fps?
By lorix in forum AudioReplies: 3Last Post: 10th Nov 2008, 14:55 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23 -
Avifrate doesn't appear to change FPS
By Maikeru-sama in forum Video ConversionReplies: 5Last Post: 14th Aug 2007, 21:04
