Hi,
I burned avi file but i have errors running it on my standalone. The audio file type is AC3. I tried changing compression with virtual dub but i couldn't and i get a message:
No audio decompressor found to decompress the audio source format
Please help.
Results 1 to 10 of 10
JKoniak
install the AC3 ACM Decompressor from the tools section.
And what I supposef to do with this .avi file. I have VirtualDubMod but I don't know what to do.
JKoniak -
If Virtual Dub mod does load the original video, save the file as a wave file (File-->Save Wave...). You then should be able to work with it then.
Hello. -
Hi
First of all there is not option in VirtualDubMod Save as wav. Secondly I tried to do that in VirtualDub but I've got message which I wrote before.JKoniak -
Sorry, on the newest Virtual Dub mod, the path is Streams-->Streams List--Save WAV...Originally Posted by jarkoHello.
I went there and I couldn't open file because of format. I can open there: supported formats.wav, mp?,ac3, ogg, dts, srt
How I can open avi file ?JKoniak -
Did you install the AC3 ACM Decompressor yet? This is necessary in order to decompress the audio so you can convert to another format. Once you do that, open your movie with Virtualdub, go to the audio menu and select "full processing mode", then "compression" and choose mp3 with the bitrate simillar to that of the original AC3(you can find out by going to File>File Information). Now go to the video menu and select "direct stream copy", go to file and save as avi. This will produce a new avi with mp3 compression that your player will hopefully decode easier.
Hey guys thx alot for helping me, everything worked out great with this.
ThxJKoniak
Source image format is not acceptable (VDMOD, XVID, AC3)
By stlolth in forum Video ConversionReplies: 8Last Post: 23rd Aug 2010, 11:22 -
AC3 doesn't work after format
By Xavier in forum AudioReplies: 7Last Post: 26th Feb 2009, 19:27 -
rip AC3 track without format change
By shun in forum DVD RippingReplies: 2Last Post: 9th Feb 2008, 04:01 -
AC3 Illegal Audio Format
By mub6 in forum AudioReplies: 11Last Post: 22nd Nov 2007, 14:29 -
Trying to Convert avi. (Dvix) with AC3 audio file to DVD Format
By carlos305 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2007, 09:54
