Is there any program where i can fix the audio/video sync after it is converted into an MPEG 2?? Every full video I have converted to SVCD has gone out of sync from the start or half way through the movie...
There is no single software that can fix svcd sync problems.
how do you convert to svcd? and from what format? -
I use Virtual Dub to extract the audio into a wav. Then i use TMPGEnc. to convert..Usually I am converting Avi's or Divx movies..They all work fine when in there normal format. I would just like to be able to fix the audio after I convert it to an SVCD..Any ideas or programs to use???
MPEG2 to MPEG4 conversion
By altavistasf in forum EditingReplies: 2Last Post: 11th Jun 2010, 23:35 -
mpeg2 to mpeg2 conversion
By asdfen in forum Video ConversionReplies: 9Last Post: 4th Oct 2009, 13:45 -
AVI to Mpeg2 conversion
By carlmart in forum Video ConversionReplies: 122Last Post: 13th Mar 2009, 06:04 -
after conversion to mpeg2 gets interlaced
By forare in forum Video ConversionReplies: 32Last Post: 13th Oct 2007, 23:47 -
AVI to MPEG2 conversion
By Alexstarfire in forum Video ConversionReplies: 8Last Post: 6th Aug 2007, 18:42
