I have installed MMC 7.1 and all programs (VCD/DVD etc...) are working except the TV tuner - even though all I want to do is capture from SVHS or COMPOSITE. When I start up it insists on running the Tuner Wizard, but when I go to auto-scan, there is no region selection in the drop down box so I can't. This means I cannot auto-scan and have to close the wizard and can't open the TV to capture. This is really annoying. Is there something I have to do to set the region?
i have to go thru the installation wizard every time i start the tv app. i just click next every time...bypassing every thing. this seems to work for me. you might give it a try.
Donadagohvi (Cherokee for "Until we meet again") -
if you are using an all in wonder radeon why don't you upgrade to a newer version of mmc. i'm using version 8.8 on a very old 32 mb radeon.
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 16:12 -
Audio/Video multi format/source selector
By YesRushGen in forum DVB / IPTVReplies: 0Last Post: 14th Jan 2011, 18:06 -
Audio/Video Selector & Output Quality
By Tom Saurus in forum Capturing and VCRReplies: 1Last Post: 15th Sep 2010, 16:27 -
Program Philips DVD Recorder DVDR 3575H/37 to be Region Free
By hyades in forum DVD & Blu-ray RecordersReplies: 1Last Post: 21st Dec 2008, 12:18 -
remote controlled a/v selector
By stackner in forum Off topicReplies: 1Last Post: 5th Jul 2008, 21:03
