HI again
I posted a meesage but unfortunately i havent had any replies.
Can anyone tell me a susbstitute for dvd decrypter?
Thnaks in advance
Results 1 to 30 of 45
Try doing a search for ripping software in the tools section. I did. It took me about 10 seconds.
Click here to show the ripping software sectionIf in doubt, Google it. -
I already did it
What i am looking for is some soft to remove the protection since i am trying to rip the godfather and decrypter says that brutal force method will be used and later that there is no key and it skips the file
PLease help -
Did you try any of the software there or just stare at it blankly ???Originally Posted by pelado
Last time I checked, there were like, 20 different progs there. If you have any more problems with it, call lordsmurf on 1800-PLZ-RTFM. He will be only too happy to help you out.
Lets stop bashing, he has the answer, lets leave it at that.
thanks for that oneOriginally Posted by jimmalenko
Well let see
I made a friendly question, now i see people insulting me
All i wanted to do was to rip godfather. Btw i tried smartripper and cant do it . Same problem
But dont worry, i wont be bothering again. Its a pity all i had was a simple question. Noo need to answer like that or to shout -
@pelado:
What part of this do you not understand ?Originally Posted by The AUP
We pointed you in the right direction and from what I can gather, you only tried 1 other program.
I was not talking to you when I explained what RTFM and STFU mean.
If you are going to continue this attitude, don't post. You'll be doing us all a favour.If in doubt, Google it. -
Ha ha, I thought STFU meant "Sit on The Face of the Universe"!!!?
And...RTFM..."Ream The F#$cken Martian"...!? -
open/play the movie in a software dvd player like powerdvd for a few seconds. That should unlock everything and it should work fine then with dvddecrypter or other ripping tool.
A cup just sounds better.
Nothing can stop me now, 'cause I don't care anymore. -
yeah, but broken bottles just work better in bar fightsOriginally Posted by ViRaL1
I definitely agree that a pool stick is "best". But we were arguing about cups and bottles. Thanks for your input thoughOriginally Posted by ricky1756
Anything bigger than a handful, you're risking a sprained tongue.
Anything more than a mouth full, the rest is just inxs & run the risk of suffocation!
ANYDVD HD Substitute
By pandemonium in forum Blu-ray RippingReplies: 11Last Post: 8th Jan 2012, 21:16 -
Substitute to Streamtransport !
By augustya in forum Software PlayingReplies: 9Last Post: 15th Jul 2011, 12:30 -
iuvcr substitute
By marcolisi in forum Capturing and VCRReplies: 1Last Post: 4th Aug 2010, 13:50 -
staxrip for mac substitute?
By malakov08 in forum MacReplies: 7Last Post: 9th Apr 2009, 00:57 -
Vista - TweakUI substitute?
By Ai Haibara in forum ComputerReplies: 3Last Post: 29th Jul 2008, 04:04
