I have a prob ur standard movie what 2 hrs long right???? when encoding a 2 hr divx to svcd i cant even fit an hour and 6 mins worth on to a 80 min cdr????, even at the lowest bite rate 1600 is there anyway around this......
Question 2, when encoding a vcd is it alright to encode over 1150?
any help regarding these questions would be much appreciated
thankyou
Jake
Jake,
welcome to the forum.
I'm gonna predict that you will get some bashing posts here for the simple reason that you obviously haven't read any articles here before posting this question.
That aside, there are a few basic points that we need to get straight. The first is this; SVCD is commonly defined as being able to hold 35-60 minutes of video (From "What is SVCD" top left). VCD is commonly defined as being able to hold 80 minutes of video (From "What is VCD" top left). I suggest you read both these sections before you do anything else.
In brief, you have no hope in hell of fitting 2 hours to 1 CD.If in doubt, Google it. -
A brief answer to your first question, is yes, there is a way around it. Do some research on KVCD.
Cheers, Jim
My DVDLab Guides -
NTSC VCD spec - 1150 bit rate, 44.1 audio 352x480 = 80 minutes on a CD
NTSC SVCD spec - VBR ranging from 2000 - 3500 (some dvd players choke on higher bit rates), 44.1 audio 480x480 = 35 minutes on a CD (sometimes can cram more based on bit rate, etc.)
DIVX/AVI/XVID spec - not really one as it relates to my post. IT can be any resolution, any bit rate, any audio and is a HIGHLY COMPRESSED FORMAT.
That is why you can fit an entire movie onto 1 CD and it looks good.
When you convert from a compressed format like avi/divx/xvid, you are uncompressing it to a DVD standard (VCD,SVCD,CVD, etc.)
As the first person that responded (and I will be shocked if you dont get flamed hard since it is VERY obvious you did no research at all), I would do some basic reading on converting XVID, etc. files to SVCD. There are a number of guides that will walk you through the process on how to do it (if you dont want to learn the reasons why).
your second question about encoding above 1150. Depends on a few things. Yes, you can encode above the SPECIFICATION of 1150, however, some dvd players may not be able to play it as those will only handle in spec VCD's (look on the left under dvd players for yours and see if it will handle it). The format is called XVCD. -
Thanks by the way sorry for any misunderstanding...... i was asking if there was any way i could fit 1hr 6 mins on svcd material on a cdr.... not 2 hrs, because 1 hour and 6 mins is rougly half the movie, and i didnt want to split the movie into three parts. I was thinking that someone would know if it was possible to fit an hr and 6 mins of svcd material onto an single cdr by way of the burning prog eg. Nero and the finalizing option
Sorry bout any misunderstanding
Thankyou -
Originally Posted by jimmalenko
To correct some inaccurate information -
VCD spec resolution is 352x240, MPEG-1. Bitrate MUST be 1150. Anything else and its not a VCD. Though it may (or may not) play in any given player.
SVCD max bitrate is 2520. There is, however, no minimum bitrate. You could make one at 500 if you so desire. It may, (or may not) look like crap.
Look into CVD res, VBR, and IVTC as the best ways to make a widely compatible disk with more than an hour of content.
Best answer? Get a DVD burner.
Help with large TS file
By mejallen in forum Newbie / General discussionsReplies: 1Last Post: 23rd Mar 2010, 19:44 -
Help to compress large HD File
By camlachie in forum Video ConversionReplies: 10Last Post: 10th May 2009, 12:47 -
large iso file
By fabpozzi in forum Authoring (DVD)Replies: 10Last Post: 13th Dec 2008, 12:10 -
Avi file too large for CD
By hitmanhill in forum Newbie / General discussionsReplies: 17Last Post: 22nd Jan 2008, 14:19 -
Large .dvr-ms file?
By ukcat in forum Newbie / General discussionsReplies: 2Last Post: 7th Sep 2007, 15:47
