I'm trying to cutt part of the .rm file up in a clip and I'm wondering what would I use to do so? Thanks.
I would suggest converting the .rm file (Real file format), to AVI first (better file format to work with). I would use a tool like EO Video (do a search in the tools section --> RM to AVI, you'll find stuff there). After you have done this, I would use VirtualDub to cut the parts out (if you are on a budget and do not want to spent money on an editing program). If I were doing it, I would use Premiere just because it's fast and easy. Hope this helps!
+If you want to eliminate the step of converting, there may be a filter for VDub that you can use to import .RM files (or maybe it already does). I have never worked with this type of file before so I don't know. Personally, I think that this format is terrible, and the quality really lacks.
Edit ISO files
By Leo48 in forum Newbie / General discussionsReplies: 8Last Post: 29th Nov 2018, 03:15 -
Can I edit HiDef files in same project as StandardDef files?
By cspaul1234 in forum Newbie / General discussionsReplies: 0Last Post: 10th Jul 2011, 19:39 -
cannot edit avi files
By DirtBikeMike in forum Newbie / General discussionsReplies: 4Last Post: 18th Jan 2010, 09:38 -
can I edit my avchd files this way
By lordhutt in forum Authoring (Blu-ray)Replies: 4Last Post: 14th Jan 2010, 15:12 -
Edit MPG Files
By bz186 in forum EditingReplies: 2Last Post: 4th Sep 2009, 14:07
