OK, confused a bit here..
I had an 84 minute DivX I wanted to try to SVCD...
So I did, and I used a low bitrate (900 I think..) and got the file size down to 664 meg.. Not bad.. Make an SVCD..
Pop it into my DVD player.. Nothing..
Ok, no surprise, mine doesn't say it does SVCDs, just VCDs..
So, I figure I'll try the header trick..
I pull up TMPeg Plus 2.5, use the VCD Header trick, convert and..
840 meg file???? WHAT?
What kind of header is almost 200 meg??
So, I try it again with VCD standard (first try was VCD non-standard)..
Same thing.. MUCH BIGGER file...
So, am I missing something, or is the header trick only supposed to change the header??
Any explanations would be appreciated...
Thanx
desiv
Although I can't explain WHY that happens, I would split the avi into two files and burn SVCD at a much higher bitrate to maintain some quality.
A 900kbps SVCD is going to be almost unwatchable, way worse than VCD (1150kbps).Cheers, Jim
My DVDLab Guides -
The point is his player does not play SVCD, only VCD. YOu could try modifying the VCD template to 352X480 MPEG-1 and encoding at 2200 kbps as a non-standard VCD. Or you could simply encode as a VCD MPEG-1 352X240 nosn-standard, but up the bitrate to 1600 kbps to get excellent quality. On small TV's (19" and smaller), you usually cannot tell the difference between a well authored VCD and SVCD/CVD other than the fact you can get the movie on one disk!
Read your post:
My guess is that instead of just the header trick, you also converted the audio up as well. The "header trick" should not increase the file size. For whatever reason, it is overstating the size. Maybe you could post some of the specifications of the file before and after you try the header trick. I believe that you can try this in nero (burn as a VCD although it is a SVCD) and it will do the header trick during the burn. OR, you could try some patching software (available on the left) to patch it to a VCD.I pull up TMPeg Plus 2.5, use the VCD Header trick, convert and.. -
Well, I tried it with a smaller original file and a higher bitrate and that one worked fine. My DVD player even played it with no problem!! Yeay! Tried my larger file, lower bitrate again.. MUCH BIGGER file result again.Originally Posted by macleod
Nope, I'm not also converting. Just try the TMPeg multiplex and click run and it converts.
I'm trying what you suggested using Nero.. I'll see what happens..
(UPDATE.. Didn't work.. It burned OK, but doesn't play. I looked at the resulting files on the CD. They both look the same in TMpegenc tools. Except for the bitrates. But only the smaller one (higher bitrate) plays on the DVD player. Both files play in PowerDVD.)
Thanx,
desiv
p.s. The file before conversion is (according to TMPeg):
MPEG-2 Program (VBR)
MPEG-2 Video 480x480 29.97fps 950kbps
MPEG-1 Audio Layer-2 44100Hz 224kbps
Those are the exact same specs of the smaller file that worked, except it's video bitrate is 2000kbps.
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 04:59 -
Is there a trick to Fairuse Wizard for output file size
By marioval in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 07:49 -
Question: MKV File Size vs MP4 File Size
By VideoNoobz in forum MacReplies: 6Last Post: 20th Feb 2010, 03:44 -
How to edit MP4 header frame size?
By Darney76 in forum Portable VideoReplies: 4Last Post: 7th Jan 2008, 22:58 -
Anyone know how to fudge the frame size in an MP4 header?
By Darney76 in forum Video ConversionReplies: 1Last Post: 23rd Dec 2007, 19:48
