I've got errors with TMPGEnc which can't be solved so I need to change programs. I'm very used to TMPG having been using it for a long time, so what's the next best thing when you are forced to used something else?
Results 1 to 17 of 17
Or Mainconcept encoder, or CCE encoder, or .......https://www.videohelp.com/tools?section=9#9
or you could try for yourself. I did and have encoded over 600 movies.
it all boils down to what you like, not what we like. Use whatever works best for you.
"Illegal floating decimal point calculation order." at the end of the first analysing pass during a 2-pass VBR encode when the real encoding begins.Originally Posted by W_Eagle
I have tried every suggestion here on this site to get around the problem and am now talking to the Pegasus support people as well. Have tried swapping RAM sticks around and even removing one of them as something else to try. Nothing has worked as yet. I was indeed one of those people you refer to who used to use TMPGEnc all the time with absolutely no errors whatsoever. Unfortunately that was with my old Duron 800MHz CPU computer. Since I "up"graded to a 2GHz Celeron however TMPGEnc won't work properly. -
And you having problems like this on an Intel board? Wow.
MainConcept, maybe? -
Mainconcept Mpeg Encoder is one of the best pieces of software i've ever used.
josh -
cce is even better (less pixelation)
mainconcept is good for high bitrates
thats what i think anyway.
try both and see for yourself.HELL AINT A BAD PLACE TO BE -
Thanks, CCE does indeed look like a reasonable alternative to TMPG. I shall give it a whirl and see how it goes.
Mine did exactly that when I tried to overclock my old Soyo SY-71WB mobo. Strangely enough, my new mobo (MSI 845GE Max-L) works fine when my 1.7GHZ CPU is running at 2GHZ...Originally Posted by DRP
Yes. The responses I'm getting from Pegasus are leading me very much to the conclusion that you are either lucky or unlucky with TMPGEnc. It will either work correctly with your mobo/CPU or not, and no-one can help or provide a solution if you're one of the unlucky ones with a mobo/CPU it doesn't work with.Originally Posted by fmctm1sw
One can only hope they will resolve these issues with the soon to be released TMPGEnc 3.0 XPress -
I can vouch for Canopus ProCoder Express. It's a steal at $59, imo.
When I encode a super-clean, high-bitrate source down to a VBR2500 with it, I'm often unable to tell that it's been done unless I compare file sizes. My favorite feature is telling it to 'watch' a subdirectory so that whenever I put a file into that directory it automatically enodes it for me. Automation saves me time.
Great tool!
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 16:07 -
tmpgenc 4 audio no AAC encoder?
By sychern in forum Video ConversionReplies: 1Last Post: 22nd Jun 2009, 22:06 -
Tmpgenc problems with divx avi's, encoder suggestions?
By kitykat_2004 in forum Video ConversionReplies: 1Last Post: 26th May 2008, 02:35 -
After reinstall of OS etc, Tmpgenc encoder can't support avi media files
By AORMan in forum Video ConversionReplies: 15Last Post: 2nd Feb 2008, 11:36 -
Better encoder than TMPGEnc
By dazza555 in forum Video ConversionReplies: 7Last Post: 15th Sep 2007, 10:45
