I am all set to buy the winfast expert card. It seems to be the best I need for the price for me anyway. I was wondering if there is any usb equivalent to that. Since I may move around with the capture device, I thought it may be better to get a usb but I don't know how good is the usb quality and how expensive are they.
Also I have a dvi-d on my video card, is that pretty much useless since I don't think they have dvi-d adapter.
even they say usb 2.0 is fast, it seems really slow to me. I used external drive with firewire, and usb, and usb was a hightmare.....
go for pci.....faster -
I'm not sure what you are asking, but if you are looking at a external capture device; You might consider a ADVC-100. It is portable between OS's and computers. Disables Macrovision. Downside: Expensive, need a Firewire card. There are USB devices that perform a similar function. You might want to look through the capture card section on this site.
Your question refers to two different busses, so yes there are differences
Pinnacle PCI or USB 700
By SerbianBoss in forum Capturing and VCRReplies: 18Last Post: 30th Mar 2011, 22:12 -
Can I install USB and PCI-e TV Wonder 650
By Damnskippy in forum DVB / IPTVReplies: 4Last Post: 3rd Mar 2009, 20:58 -
internal pci and a usb adapter
By vipertongn in forum ComputerReplies: 6Last Post: 27th Jul 2008, 16:06 -
capture device: usb or pci?
By danica in forum Capturing and VCRReplies: 2Last Post: 5th Sep 2007, 12:04 -
PCI/PCI Express 1x usb 2.0 card with 2 internal usb inputs
By SIRCOOKS in forum ComputerReplies: 0Last Post: 24th Jun 2007, 11:58
