  1. Member Bronx's Avatar
    Dec 2003
    Bronx, New York
    I have used plenty of guides on this site and most of them have worked for me. I have used the Tmpgenc plus guides on how to convert avi to mpeg2.
    I know there is a guide for MC but it is for vcd. Is there a guide on how to convert avi to mpeg2 (dvd) using Mainconcept Mpeg or is anybody working on one.
    Thank you in advance.
  2. Mainconcept is so easy, you don't really need a guide.
    If you can make a VCD, you can make a DVD.
    Adjust quality and size settings to fit on a dvdr.
    Cheers, Jim
    My DVDLab Guides
  3. Member Safesurfer's Avatar
    Mar 2004
    Why not just download the pdf manual from Mainconcept?
    http://www.mainconcept.com/downloads.shtml
  4. Member Bronx's Avatar
    Dec 2003
    Bronx, New York
    I have the that guide. I was wondering if there is one that shows you how to modify settings like some tmpgenc.
  5. What settings do you want to modify? The default template is about as good as it get's. Changing the more advanced options is going to require much more reading/learning than most people want to bother with.
    Cheers, Jim
    My DVDLab Guides
  6. Member Bronx's Avatar
    Dec 2003
    Bronx, New York
    Thanks for your reply.
