Is it possible to copy a DVD-ROM disc which is larger than 4.7GB? Are there larger capacity discs available, and if not how do the software companies fit so much on one disc?
Thanks Travis
For a DVD-Video disc try DVDShrink. It takes a dual-layer DVD that's as much as 8 or so GB and recompresses it down to fit on one single-layer. It works quite well.Originally Posted by tbarrnes
For software I don't know if DVDShrink will work. I doubt it. Software doesn't tolerate lossy compression well
You may be stuck with WinRAR or WinZip.
There are dual-format burners on the radar screen but they're still months off for DVD+R and as much as a year for DVD-R. They will burn DVD-9 dual-layer discs which are 8+ GB. -
PLEASE only post video related stuff in the video forums. I'm moving you.
They can fit so much because they use pressed dvds rather than burnt Dvd (unless they are really only going to produce 100's) that means the blanks have a capacity of up to 18gb (and they use compression)
Alcohol 120% would allow you to make an image of it and mount it as if it were a drive i.e. assign the image a drive letter i.e. f:\ and the computer thinks that the disc is in the drive.
"We were in barstow on the edge of the desert when the drugs began to take hold."
Installed software ,No Discs?
By visionman in forum ComputerReplies: 5Last Post: 14th Jan 2009, 17:43 -
Software fails to recognize DVD-RW discs
By Mummyscurse in forum DVD & Blu-ray RecordersReplies: 8Last Post: 24th Oct 2008, 17:07 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 17:05 -
dvd rom discs
By johnbud in forum MediaReplies: 3Last Post: 26th Jul 2007, 07:03 -
Please suggest a software for me for joining DVD discs.
By csh in forum EditingReplies: 3Last Post: 9th Jun 2007, 23:29
