I am trying to convert some divx files to vcd using Nero 6.
The files are approx 720MB so i have bought some Infiniti 900MB cdr's to burn them onto.
Does anyone know how much this divx file would end up after converting to vcd?
I have set up nero 6 to overburn and set it at a maximum of 98:58 secs but when i look at the disc info it still states 703MB.
Is this right?
I would really appreciate any help on using Nero 6 correctly etc.
Many thanks in advance...
You will also need a burner capable of burning 90/99 min discs, check the writers info on the left<----, good luck!
My cd burner is ok for 900Mb discs.
Can anyone help with my above post please.
Thanks -
Depends on how long your movie is. VCD's take up around 10mb per minute.
Need help and guidence...Convert 4.5gb to 900mb using Megui
By u4upendra in forum Video ConversionReplies: 2Last Post: 28th Jun 2011, 04:14 -
Convert DVd to xvid avi best quality for max size 900mb
By selwyns2828 in forum DVD RippingReplies: 6Last Post: 10th Feb 2011, 17:02 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 13:36 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 22:29 -
900mb avi to 700mb vcd
By dck42069dck in forum Video ConversionReplies: 7Last Post: 4th Mar 2008, 13:33
