heLLO, i AM GOING TO reformat my PC but, I have so many web pages on favourties that it is going to take to long to writed down, Does anybody know how to like have shortcuts to favourites so I can save it to disc
If you are using explorer, File>Import and Export, then save to a floppy. To reinstall, same place. Most browsers have a similar function.
Although you didn't ask this question, you might want to "relocate" your favorites to a more convenient location for ease of update, and so you can back them up very easily (of course, redwudz suggestion is always good for that). To officially change your favorites location (and some other default locations), do the following:
Run Regedit
Go to HKEY_CURRENT_USERS\Software\Microsoft\Windows\
CurrentVersion\Explorer\ShellFolders
Double click on the Favorites in the right panel
Change it to what you want (like C:\Favorites)
Click OK
Do the same thing in User Shell Folders a few lines down
Close Regedit
Move your favorites to C:\Favorites (example)
Your Favorites are usually under C
ocuments and Settings\Your User Name\Favorites
you can just save the "Favorites" folder (should be located in documents and settings under your username) then when you reformat just go to documents and settings folder select user and then move the Favorites folder you saved there and overwrite the default Favorites folder
i do this all of the time, it works with no problems and really easy to get your favorites back, hope this helps
alright
Use My ip camera in my website
By AMZ in forum Video ConversionReplies: 17Last Post: 16th May 2015, 17:42 -
This website
By Will Hay in forum Off topicReplies: 24Last Post: 17th May 2013, 18:11 -
ISP problem - some website pages load, other website pages don't
By PartingShot in forum ComputerReplies: 15Last Post: 7th Sep 2012, 00:42 -
DV import help
By VirtualDoobMon in forum MacReplies: 3Last Post: 4th Mar 2008, 02:34 -
Dvd to website
By trugamer79 in forum DVD RippingReplies: 5Last Post: 18th Sep 2007, 21:00
