hi,
which are the best tools for dvd decryption, conversion and burning?
i have dvd decrypter and clone dvd2 and inter vdeo copy dvd 2!!
thx
I'm a huge fan of DVD Shrink. It both decrypts and encodes a DVD you wish to back-up and easily allows you to leave out things you don't want (like certain subtitles or extra features). I've been very happy with the results and it's easy to use for backing up episode DVDs. I use Nero 6 for burning but don't really use a conversion program.
Bright Knight -
i dont understand the following in dvd shrink! how can i leave out menu and extras????? i dont get that ! i unclicked menu and extras and then i saw that after the compression everything was in!!!!!!!!!!!!
thx -
i am wondering which is the best for dvd back up? dvd decrypter or dvd2one???
thx -
You have to select re-author, not back-up full disc in DVD Shrink. If you select re-author it should show you three headings on the right side - menus, titles, and extra features. Not sure if that's the exact description, don't have it in front of me but I know if you select main title and drag it to the left side, it will only back up the movie - no menus, no special features. If you did a full disc back-up and didn't check all the boxes on the menus and extra features, you were only getting rid of subtitles or audio settings. Holler if you're confused or run into trouble.
B Knight
Best DVD ripping tool?
By bkkfrank in forum DVD RippingReplies: 4Last Post: 6th Oct 2009, 12:54 -
Which DVD Authoring Tool ?
By Leo48 in forum Authoring (DVD)Replies: 5Last Post: 1st May 2008, 15:37 -
Which DVD Authoring tool to use?
By jodajen2 in forum Authoring (DVD)Replies: 6Last Post: 14th Nov 2007, 09:21 -
Best DV to DVD conversion tool
By whenloverageswild in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 24Last Post: 2nd Nov 2007, 00:50 -
Best tool for DV AVI -> DVD?
By timmus in forum Newbie / General discussionsReplies: 1Last Post: 7th Oct 2007, 11:58
