I Have a VOB File and want to convert it to Mpeg 2 for DVD use.
I have tried a lot of Freeware and Shareware to try to convert it Like . Tempgenc, DVD Architect, DVDLab, Virtual dub and lots of other tools, If I try to demux the file it stops demuxing without a error at 1:50 or so, or it crashes. Some do the whole movie but then the movie is slow and stutters. If i play the original VOB on my PC there seems to be nothing wrong. I Don't know the source but it is a Promo clip.
Any Suggestions ?? Please
The VOB is dvd ready (needs other parts to the structure, but is closer to dvd than mpeg2). If you are wanting to take the VOB and convert to MPEG2 for editing, you could:I Have a VOB File and want to convert it to Mpeg 2 for DVD use.
1)rename the extension to .mpg
2)use isobuster to extract the vob file
TMPGENC DVD Author will take VOB files (unencrypted), which you can then edit with. -
I've tried to import the vob into DVD-Lab, but if I click the option Demux , it dumuxes only 1:30 min of audio but the whole clip is 5 min or so.
The video stream seems to be ok, I think the audio stream is broken somehow.
But first I'll try your suggestions. (I'll let you know the result). -
Create a DVD2AVI project then encode to a mpg with tmpgenc
Go to file/open and load your VOB files. If the files are consecutively named selecting the first VOB will load all the others.
at Audio/track number select track 1 and at Audio/Output method slect decode to wav.
go back to file/save project. this will create a .wav and .d2v file
start tmpgenc load .d2v for video source and .wav for the audio and encode.
Black screen, but Audio is fine - when playing after rendering
By DUCKVILLELOL in forum Newbie / General discussionsReplies: 0Last Post: 14th Dec 2010, 06:06 -
Problem playing newer 720p files (1080p works fine)
By twoplustwo in forum Software PlayingReplies: 5Last Post: 13th May 2010, 19:04 -
Playing a clip every 15 mins
By christian_j in forum Video Streaming DownloadingReplies: 0Last Post: 6th May 2010, 14:30 -
a few m4v files have no audio when playing in iTunes...work fine in qt/vlc
By bobogs in forum DVD RippingReplies: 0Last Post: 18th May 2009, 21:21 -
Authored DVD with GFD, fine on TV, no menus when playing on computer.
By towtruck in forum Authoring (DVD)Replies: 6Last Post: 8th Jun 2007, 18:40
