This may be a loaded question, because I know how touchy everyone can be about their "Favoritre software"...but here goes:
If' i'm capturing video from a digital camcorder, editing, then outputting back to Digital video quality AVI format,, are different programs going to give me different quality video, since it's essentially the same standard? I've used both Video Explosion deluxe, and Studio 9, and I"m not sure that THe studio 9 is quite as good as the VE outputted file. I'd love any comments or suggestions!
Thanks very much in advance!
JPT
Strange, there shouldn't be any difference in quality if it is a DV camcorder.
Why not?Originally Posted by DivXExpert
When omnpotnt edits the file, some codec installed on the PC decompresses it. The editor then changes it. Then some codec recompresses the file, before it is sent back to the cam.
Even though DV is a standard, I doubt all codecs are equal, and I very much doubt all editors are equal.
So if you see a difference, there are very good reasons why there might bee a difference.
I see. I thought he was saying that he captured with one program, then another, and the quality was different. Which doesn't make sense, because the "capture" is actually just a data transfer from the tape, which was compressed by the DV chip in the camera.
If your programs are re-encoding the video then different progams may have quality differences, but it's always better not to re-encode as that always results in quality loss. If you're only cutting and splicing then it's possible to do that without re-encoding. If you're actually changing the footage (transitions, hard subtitles, filters etc.) then re-encoding is unavoidable.Originally Posted by omnpotnt"Art is making something out of nothing and selling it." - Frank Zappa
omnpotnt: Here's a link to the Doom9 forums that discuss different DV codecs that can be used to output DV to a video file: http://forum.doom9.org/showthread.php?s=a402018d35da7c389655c95cc5c0ec2e&threadid=33526
Quality difference with MKV?
By pixaren in forum Software PlayingReplies: 4Last Post: 21st Jun 2011, 11:12 -
quality difference for multiple reincodes
By resloan in forum Newbie / General discussionsReplies: 14Last Post: 30th Mar 2010, 21:31 -
Video Captured Low in Quality/Resolution
By kakashi123 in forum Capturing and VCRReplies: 4Last Post: 10th Jul 2009, 18:36 -
Captured HD Video - want to put on DVD in HD quality
By Coroner in forum Newbie / General discussionsReplies: 6Last Post: 7th Dec 2008, 15:32 -
Will there be a difference in output quality?
By ingeborgdot in forum EditingReplies: 55Last Post: 21st Sep 2008, 18:41
