I have the dvd files ready to burn, that dvd compilation has no menu, only the movie itself, is it any way to add these files a simple menu withou make any coding process over the movie? , thanks.
Yes, just create your menu then map out your buttons. You will have to re-compile, though. This will take anywhere from 10 to 30 minutes, depending on your authoring package.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W
Add 5.1 to m4v file without reencoding video?
By jaredhite1 in forum AudioReplies: 3Last Post: 14th Feb 2012, 02:12 -
Add borders to MKV without reencoding?
By squadjot in forum Video ConversionReplies: 3Last Post: 16th Nov 2010, 13:53 -
Add chapters to MPEG4 MOV without reencoding
By Jonya in forum Newbie / General discussionsReplies: 2Last Post: 5th Feb 2010, 16:41 -
Add a watermark to .avi x Reencoding
By dexter30 in forum EditingReplies: 21Last Post: 8th Sep 2009, 21:42 -
Add JPEG as First Frame - Windows Explorer Preview - Without Reencoding..
By aces27 in forum EditingReplies: 1Last Post: 28th Feb 2008, 09:07
