I posted another topic just now but its starting to get a little off topic there.
I capped some videos in MPEG2,and used vdubmod to save the wav and then use goldwave to time warp it to the same length as the video and then encode it together with audio skew correction at -500 ms,it may sound confusing I know.
The audio sync was fine at the beginning,but it begins to get off sync towards the end,gradually,the audio begins to go off sync with the video,usually faster than the video. Example is,the audio goes 1ms off sync every 1 sec which makes it goes 1 sec off sync every 100 secs. How can I fix/prevent this?
System/computer specs isn't important in this case. At the same time,my encoded video seems to be 1 frame less than the original MPEG2 as in the MPEG2 has 58949 frames but the encoded video has 58948 frames which causes a 34ms difference in the audio. How can I remove the 34ms from the audio and will it fix the sync problems? Does audio interleaving in vdub cause this problem too?
This is quite important,I need to get the videos done by friday,so I gotta fix this by thursday/friday.
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
How to fix gradual loss of sync once and for all
By Acidagent in forum User guidesReplies: 76Last Post: 22nd Oct 2009, 06:39 -
Win DV sound prob
By prcole18 in forum Capturing and VCRReplies: 7Last Post: 14th Jul 2008, 15:07 -
sound prob on dvd from mkv
By umpaflumpa in forum Video ConversionReplies: 2Last Post: 20th Dec 2007, 11:02 -
audio sync prob AFTER burning !
By bluraid in forum Newbie / General discussionsReplies: 5Last Post: 21st Jun 2007, 05:28
