  1. I really hope someone can help. I'm getting blue video on WMP9, BSplayer, Realplayer, and Winamp video and others. The strange part is WMP 6.4 plays most videos fine. I would use that program but my TV card is also blue video and Power DVD 5 is blue. I have installed Nimo5 b8 and K-lite mega codec pack 1.01. I later removed them since they didn't fix the problem and also went into Control Panel/Sound and Audio Devices/Hardware/Video Codec and removed all the video codec that wasn't listed on another XP system that was working. I have trying reinstalling DirectX 9 and a few others but nothing is helping with this. If anyone can help I would be very very thankful. If anyone needs more info please asked because I'm at a stand still as to what to try next.
    Thanks very much for any help that you can give.
    USA
    Still sounds like a codec problem. Not sure where to go since you uninstalled most of the ones that might be the problem. Either one is still corrupted or they didn't completely uninstall. You could run AVIcodec and that will also tell you what is installed. Hopefully someone else can come up with an idea for your problem.
  3. That's plain strange. I'd almost say your monitor cable's connection to your video card is loose...
    Dec 2002
    Toronto, Canada
    I'm having the exact same problem but with WinXP Home. Netzeus please let me know if you get this problem solved and I will do the same for you. Thanx very much in advance.
    Idioteque74
  5. Thanks everyone for the ideals. I'm still looking for a fix. If I figure out the problem I will post the answer.
    Thanks again
