There's been a few times when I have taken a few MPEG files that play for 15 or 20 minutes but once I import to ULEAD, it cuts off almost 80%, i.e. the file is only 1 to 2 minutes in length.
Why is this happening? Is there a better program that I can use to use for SVCD or VCD? I have a DVD Burner too, but this sometimes takes too long.
Suggestions?
Hi retroz,
I think from your post that you are wanting to make (S)VCDs from MPEGs that you already have.
First of all, the MPEGs need to be (S)VCD compliant - check the blue links (top left of the page under "What Is") for VCD and SVCD for the specs. Then use AVICodec to get details on your MPEGs.
Check out VCDEasy for creating (S)VCDs from compliant MPEGs.
Hope that helps. Good luck....There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Capturing video files from tv to Ulead Software program
By soccergirl in forum Capturing and VCRReplies: 0Last Post: 23rd Nov 2009, 21:48 -
Ulead DVD Movie Factory won't burn DVDs after had been working fine
By alh132 in forum Authoring (DVD)Replies: 4Last Post: 12th Mar 2009, 15:47 -
What's the best-easily working program to rip sound from vcd ?
By billyww in forum AudioReplies: 1Last Post: 20th Jan 2009, 06:30 -
Audio not working in Ulead VideoStudio 8.0 SE DVD
By darts44 in forum AudioReplies: 9Last Post: 23rd Jul 2008, 07:54 -
MPEG1 Editing Program?
By MindF in forum EditingReplies: 3Last Post: 2nd Apr 2008, 13:28
