I tried to backup master and commander twice with shrink. And each time it would start the burning process it would only write the lead in and the error message pops up what could be the cause ?
Are you burning directly after transcoding / copying to a temp folder using Shrink to burn ( really using nero ) ? You don't say so I can't try to shed any light on this otherwise.
Tell us exactly what you are doing. Could be anything. I use shrink CONSTANTLY!!! Never have any problems ripping with os without compression and going write into burning. I have both a Rom drive and an external DVD burner. Takes no more than an hour even with deep analisys enabled. I just walk away and when I come back the backup is sitting on the ejected tray.
So tell us step by step what you are doing and we will take it from there.No DVD can withstand the power of DVDShrink along with AnyDVD!
dvdshrink
By Faerel in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2010, 23:07 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
Once I've used DVDshrink, then what?
By craniac in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2008, 17:17 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
