  1. I really need help with this one. Everytime I try to burn a dvd this error occurs. I can still burn cd's fine, I just have problems with dvds. I have used shrink dvd to rip the dvd's and then I get the error when it tries to burn it onto the dvd. I tried using nero 5.5.10.56 and this also didn't work. I cannot even burn data onto the dvd's without the error occuring. I have searched all over the net and many people have had the same problems but no-one seems to be able to help people with it. Can someone please help me. Here is the log file of the error
    Shane
    1502-4230-1279-0757-2957-5706
    Windows XP 5.1
    IA32
    WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10/09/1999 9:06:00 PM
    ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 30/01/2003 7:37:36 AM
    Nero Version: 5.5.10.56 (Nero Express)
    Recorder: <TOSHIBA DVD-ROM SD-R6012>Version: 1733 - HA 0 TA 1 - 5.5.10.56
    Adapter driver: <atapi> HA 0
    Drive buffer : 2048kB
    Bus Type : default (0) -> ATAPI, detected: ATAPI
    CD-ROM: <TOSHIBA DVD-ROM SD-R6012>Version: 1733 - HA 0 TA 1 - 5.5.10.56
    === Scsi-Device-Map ===
    DiskPeripheral : IC25N080ATMR04-0 atapi Port 0 ID 0 DMA: On
    CdRomPeripheral : TOSHIBA DVD-ROM SD-R6012 atapi Port 0 ID 1 DMA: On
    AutoRun : 1
    Excluded drive IDs:
    CmdQueuing : 1
    CmdNotification: 2
    WriteBufferSize: 70254592 (0) Byte
    ShowDrvBufStat : 0
    EraseSpeed : 0
    BUFE : 0
    Physical memory : 479MB (491036kB)
    Free physical memory: 219MB (224684kB)
    Memory in use : 54 %
    Uncached PFiles: 0x0
    Use Static Write Speed Table: 0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Enabled (1)
    Wizard: On
    18.4.2004
    UDF/ISO compilation
    3:29:17 PM #1 Phase 112 File dlgbrnst.cpp, Line 1655
    DVD-Video files reallocation started
    3:29:17 PM #2 Phase 114 File dlgbrnst.cpp, Line 1655
    DVD-Video files reallocation completed (no file modified)
    3:29:17 PM #3 Text 0 File Isodoc.cpp, Line 7604
    Iso document burn settings
    Determine maximum speed : FALSE
    Simulate : FALSE
    Write : TRUE
    Finalize CD : TRUE
    Multisession : FALSE
    Burning mode : DAO
    Mode : 1
    ISO Level : 1 (Max. of 11 = 8 + 3 char)
    Character set : ISO 9660
    Joliet : TRUE
    Allow pathdepth more than 8 directories : FALSE
    Allow more than 255 characters in path : FALSE
    Write ISO9660 ;1 file extensions : TRUE
    3:29:17 PM #4 Phase 111 File dlgbrnst.cpp, Line 1655
    DVD-Video files sorted
    3:29:17 PM #5 Text 0 File Reader.cpp, Line 115
    Reader running
    3:29:17 PM #6 Text 0 File Writer.cpp, Line 125
    Writer TOSHIBA DVD-ROM SD-R6012 running
    3:29:18 PM #7 ISO9660GEN -11 File geniso.cpp, Line 4571
    First writeable address = 0 (0x00000000)
    3:29:18 PM #8 ISO9660GEN -11 File geniso.cpp, Line 4571
    3:29:18 PM #9 Text 0 File Burncd.cpp, Line 3773
    Turn on Disc-At-Once, using DVD media
    3:29:18 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 672
    Setup items (original item values)
    0: TRM_DATA_MODE1 (CTransferItem)
    2 indices, index0 (150) not provided
    original CD pos #0 + 1742928 (1742928) = #1742928/387:19.3
    relocatable, CD pos for caching/writing not required/required, no patch infos
    3:29:20 PM #11 Text 0 File DlgWaitCD.cpp, Line 229
    Last possible write address on media: 2298495 (510:46.45)
    Last address to be written: 1742927 (387:19.02)
    3:29:20 PM #12 Text 0 File DlgWaitCD.cpp, Line 234
    Write in overburning mode: FALSE
    3:29:20 PM #13 Text 0 File DlgWaitCD.cpp, Line 1703
    Recorder: TOSHIBA DVD-ROM SD-R6012, Media type: DVD-RW
    Disc Manufacturer: OPTODI - SCK001
    Disc Application Code: 64, Disc Physical Code: 214
    3:29:20 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 824
    Prepare recorder TOSHIBA DVD-ROM SD-R6012 for write in cue-sheet-DAO
    DAO infos:
    MCN:
    TOCTYPE: 0x0 Session Closed, CD fixated
    Tracks 1 to 1:
    TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 -725143552
    3:29:20 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 672
    Setup items (after recorder preparation)
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1742928 blocks [TOSHIBA DVD-ROM SD-R6012]
    3:29:20 PM #16 Phase 24 File dlgbrnst.cpp, Line 1655
    Caching of files started
    3:29:20 PM #17 Phase 25 File dlgbrnst.cpp, Line 1655
    Caching of files completed
    3:29:20 PM #18 Phase 36 File dlgbrnst.cpp, Line 1655
    Burn process started at 1x (1,380 KB/s)
    3:29:20 PM #19 Text 0 File ThreadedTransferInterface.cpp, Line 1978
    Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
    3:29:20 PM #20 Text 0 File DVDR.cpp, Line 1323
    Recording mode: Sequential Recording Mode
    3:29:20 PM #21 Text 0 File Mmc.cpp, Line 19546
    Set BUFE: supported -> ON
    3:29:20 PM #22 Text 0 File DVDR.cpp, Line 1437
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    3:29:20 PM #23 Text 0 File Cdrdrv.cpp, Line 7933
    ---- DVD Structure: Physical Format Information (00h) ----
    Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD-RW (3), Part Version: 2
    Disc Size: 120 mm, Maximum Rate: 10.08 Mbps (2 h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 30000 h
    End Sector Number in Layer 0: 0 h
    Data in Burst Cutting Area (BCA) does not exist
    Media Specific:
    00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    3:46:57 PM #24 SCSI -1135 File Cdrdrv.cpp, Line 1447
    SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x028A0000
    Status: 0x04 (0x01, SCSI_ERR)
    HA-Status 0x00 (0x00, OK)
    TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key: 0x03 (KEY_MEDIUM_ERROR)
    Sense Code: 0x0C
    Sense Qual: 0x00
    CDB Data: 0x2A 0x00 0x00 0x0A 0x17 0xA0 0x00 0x00 0x20 0x00 0x00 0x00
    Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
    0x00 0x00 0x00 0x00 0x0C 0x00
    3:46:57 PM #25 DVDR -1135 File Writer.cpp, Line 333
    Write error
    3:46:57 PM #26 Text 0 File ThreadedTransfer.cpp, Line 222
    all writers idle, stopping conversion
    3:46:57 PM #27 Text 0 File ThreadedTransfer.cpp, Line 216
    conversion idle, stopping reader
    3:46:57 PM #28 Phase 38 File dlgbrnst.cpp, Line 1655
    Burn process failed at 1x (1,380 KB/s)
    3:46:57 PM #29 Text 0 File Scsicmd.cpp, Line 406
    SCSI not using temporary buffers
    20 out of 20 temporary buffers allocated
    Existing drivers:
    File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 10/09/1999 9:06:00 PM
    File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 28/10/2003 9:02:00 PM (Prassi/Veritas driver for win 2K)
    File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 29/08/2002 5:00:00 AM (Adapter driver for rec)
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
  2. Sounds like a collision of ASPI layers.
    Something you could try is the rename "Wnaspi32.dll" file in your system directory to "Wnaspi32.dll.BAK", and then copy the Nero file; "Wnaspi32.dll" from the Nero directory to system directory. Then reboot.
    If it doesn't work its easy to change back.
    This only works with Win2k & XP, but has the advantage of updating ASPI for any CD-burning software to include USB support.
    I'm currently using Adaptec ASPI v4.72 / Nero (wnaspi32.dll) v2.0.1.59, and have no problems with any ASPI accessing software.
    (Exact Audio Copy, CDex, Nero 5.5, CDRWin, burnatonce, Xduplicator, SmartRipper, DVD-Decrypter, IsoBuster, etc)
  3. Thanx for the tip, but once again no success. Just produces the same error, I have also tried to use copytodvd, but it still produces an error, any more ideas anyone?
  4. Have you noticed any other strange problems with ASPI in the past?
    I personally don't trust Adaptec ASPI 4.6 (1021) on anything other than Win95, Win98, or WinN4. Consider vers 4.72, and possibly the "Exclude Miniports" fix.
    Last thing, I just did a quick check on Google, and noticed 3 things in common with most of the posts.
    #1. Nero
    #2. PXHELP20.SYS (Prassi/Veritas driver for win 2K)
    (I think this is a Windows driver supplied by Veritas)
    #3. The phrase "I have a problem"
    even found similar post;
    https://www.videohelp.com/forum/archive/t171966.html
    Another page shows this as a possible fix;
    (I'm on Win2k, and this is WinXP service)
    The way I fixed it was the following:
    In the RUN dialogue box type: services.msc
    Scroll to the IMAPI CD-Burning service. Right-Click & select PROPERTIES and then on the General Tab, select disable in the Startup type.
    Once this is done Nero started burning like normal.
    What other burning software do you have on your system?
    Are there updates available for your other software? For Windows?
