Can you print using a Epson R200 on Ritek Ridata Matte Finish G04 or do i need to go buy a new batch of dvd's?
you need INKJET printable disks to use in the printer anything else and the ink will never stick...
Not bothered by small problems...
Spend a night alone with a mosquito -
Yes you can print on Ridata IW, white matte printables with your Epson. Ridata matte printables are generally crap...but they make work well for you.
Have you tried a brand called Goallover if you are in the UK these disk are brilliant they have a POSG04 lead in and it has to be said they are on a par with my usuall Piodata G04 printable, they have a far better print surface and a 1mm silver edge around the disk giving them that really proffesional look.
you can find them here.
http://www.nexus22.com/en-gb/dept_12.html -
Have you been using the disks for long ?Originally Posted by william123
I ask as Pinco's worked fine for me till i came to copy data later and found it next to impossible to extract....Not bothered by small problems...
I have been using them for around 4 weeks and I have had 2 blow out and they were my fault. I have used Princo Printable they were good when they first came out but have gone down the pan over a period of 6 months, thats why I went over to Ritek but know with these new disks I have had excellent results and no come backs which has to be good also the guy I am buying them of is offering me a one on one swap out on defective disks shom me someone who offers that on Princo or Ritek.
Matte box options for the GH1
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 2nd Oct 2009, 03:20 -
Track Matte Key problem with Adobe Premiere CS4````
By v0yAgEr in forum EditingReplies: 0Last Post: 5th Jul 2009, 14:37 -
After FX Keylight v DV Matte Pro Sony FX1
By Chummy in forum EditingReplies: 0Last Post: 2nd Apr 2009, 11:33 -
Difference matte?
By Abiyad in forum MacReplies: 3Last Post: 22nd May 2008, 15:38 -
Matte Painting Fun
By guns1inger in forum Off topicReplies: 5Last Post: 12th May 2008, 08:01
