Can anyone recommend a good cable modem under $100?
Yeah go with whatever the cable company gives you.Originally Posted by glockjs
That statement doesent help me buddy. I dont want to pay the rental fee.Yeah go with whatever the cable company gives you.
Toshiba and Motorola seem to be highly regarded. I would check with your ISP to make sure what their requirments are. Odds are DocSIS II and maybe a few others standards.
I would tend to echo what 808 said -- as I'm sure he meant if possible purchase elsewhere, the make and model your cable provider is currently offering. Mine is a Motorola unit -- same as they wanted to lease me. -
aahhh, any modem will really work... im still usin the same cheap one from 2 years ago. speeds are really dependent on the cable companys systems not the modem
All good answers but when I first got Roadrunner (have since switched) I went through two 3Comm modems before getting a Toshiba that worked for a couple years. Both repeatedly had "hangups" and had to be rebooted every couple of days. Finally got a Scientific Atlantic and haven't rebooted since (well, not because I had too).aahhh, any modem will really work... im still usin the same cheap one from 2 years ago. speeds are really dependent on the cable companys systems not the modem
There is something to be said for getting a modem brand that your provider recommends. If you don't, first time you call with a problem that's what they will blame.
ADVICE: Turning in dead cable modem
By Frank-0-Video in forum ComputerReplies: 6Last Post: 15th Mar 2010, 09:57 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 12:21 -
Should I invest in a 2ghz coax splitter for a cable modem?
By yoda313 in forum ComputerReplies: 4Last Post: 23rd May 2009, 08:06 -
Recommendations for a USB Cable Tuner
By Boegy3 in forum Newbie / General discussionsReplies: 0Last Post: 4th Aug 2008, 13:21 -
Silly question about cable modem and PC
By cim in forum ComputerReplies: 15Last Post: 7th Jul 2007, 18:15
