I'm having problems playing back videos on my system that I just installed. The video is fine (not jerky/studder), but the video colour is off. It's the same for both DVD and DivX playback. If I play the video in VirtualDub the colour is fine though. Hasd anyone else had this problem and if so, do they know how to fix it? Thanks very much in advance for any help.
I think providing screen caps of the original and the same frame from the copy that shows the problem would probably make it slightly easier to see what you mean, at least.
The most obvious question to ask is if you are paying attention to the colour balances you use when you sample the video into your computer.
It is also worth pointing out that you really should describe the entire procedure you use to get your video from source material to DVD-R so that people here might be better able to see where you are going wrong.
problems capturing with dazzle DVC100 and s-video no color
By rekotc in forum Capturing and VCRReplies: 14Last Post: 23rd Dec 2010, 04:56 -
Video playback problems after installing video editing suite - Please help!
By abeelandig in forum Software PlayingReplies: 2Last Post: 5th Aug 2010, 21:54 -
Converting a color video to black and white apart from one color. Possible?
By SteveLock in forum EditingReplies: 7Last Post: 23rd Feb 2009, 08:04 -
[color=blue]video oediting software for ASUS Eee PC (white ones)[/color]
By helpmepls in forum Newbie / General discussionsReplies: 1Last Post: 6th Feb 2009, 07:53 -
captured video has bad color problems
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2007, 04:24
