After the conversion (very long) from DivX to a DVD, I find that playing back the DVD structure from the HD using the Apple DVD Player stutters - by that I mean it playes back a few seconds then skips a frame or two and so on..
Playing the smae DVD structure in VLC or the .img in MPlayer plays perfectly.
At first I thought that the DVD structure may be faulty so I burned the .img to a DVD-RW and tried that in my domestic DVD player which played the DVD without fault.
This 'stuttering' has only manifested itself on the last couple of releases of ffmpegX, so I was wondering whether there had been any option changes that might account for it.
W.I.Bbler
How odd. I have seen the stuttering you mention, but not since 9b. Back then my workaround was to author in sizzle instead, using the ffmpegx m2v and mpa. This usually (90%) worked. But even more oddly it wasn't foolproof, sometimes even my sizzle ones stuttered. Sometimes re-encoding the whole thing made the stutter go away, go figure. I never did find out why, but I assumed I had mis-clicked somewhere.
I have a similar problem but with Sizzle. I have converted 2 divx movie in .m2v + .ac3 (Fast DVD preset) then imported and authored with Sizzle. The DVD image created by sizzle is unreadable with the OSX DVD Player (sluttered) but readable with VLC. I f i burned this image on a DVD, i have the menus on an home Pionner player (lecteur de salon in french) but the video sluttered. The same DVD on a Philips player, the menus is skipped but the video played fine.
Are Sizzle & DVDSP the only programs to author DVD on OSX?
TocheTi 867 MHz - 768 Mo - Airport - 10.3.4
ffmpegX 0.0.9m [REG]
I have iDVD but i think it cannot use mpeg2 & AC3 ?!?Originally Posted by thoughton
I have use 0.5 first (with menus) and then back to version 0.1
Correct me if what i say is wrong but with Sizzle 0.1, it's not possible to have menus with images, background, audio...
Anyway thanks for your reply,
Full Blu-Ray Rip on HardDrive Stutters on Playback
By skywalka in forum Blu-ray RippingReplies: 0Last Post: 27th Jul 2011, 01:07 -
Video playback stutters after AVI to ISO conversion
By JP9656 in forum Video ConversionReplies: 8Last Post: 7th Jan 2011, 16:46 -
Video stutters when deinterlaced an when played in a DVD player
By Kado in forum Video ConversionReplies: 17Last Post: 13th Aug 2010, 13:03 -
video (avi) playback skips and stutters in all players in windows xp
By ericgregory in forum Software PlayingReplies: 12Last Post: 28th Jul 2010, 17:01 -
DVD/Video stutters in Windows Media Player and DVD-Players, but not in VLC
By Kado in forum Authoring (DVD)Replies: 0Last Post: 25th Jul 2010, 09:30
