Hi, why does all DVD players play DVD with AC3 or MP3 sound encoded. But only certain DVD players can play the DVDs with LMCP sound format. I happened to have a DVD player that doesn't play DVDs with LMCP sound format. What's do I need to look for when getting a DVD to play DVDs with LMCP format???![]()
Good evening! Cornfussed, are we?
LPCM is a 100% 'legal' audio format. So is AC3. MP2 is only considered 'legal' in PAL-land. All DVD players must play LPCM audio streams, else they cannot put the DVD logo on their front panel.
However, you have to master LPCM streams at 48 kHz or they won't be recognized by the player. I guess my first question is, are your streams at 48 kHz, or possibly 44.1 kHz? -
Thanks Indolikaa,
You're saying that all DVD player is capable of playing LMCP at 48khz. So does that mean certain recreated DVDs LMCP are wrongly set at 44.1Khz. So the best solution would be for me to reconvert the LMCP back to 48khz. What other Khz is the standard for all DVD players???? -
Originally Posted by torex88
I'd check and see if that's the case. 44.1 kHz is a very common mistake when it comes to DVD authoring. I do it at least once per month because I'm not paying attention to what I'm doing.
Convert your PCM back to 48 kHz. Unless you have another underlying problem, that will fix it.
I believe 96 kHz is also considered 'DVD Legal' by the DVD Forum... -
MP2 is valid for PAL but not NTSC."Art is making something out of nothing and selling it." - Frank Zappa -
24/96 and 16/96 are in the spec but not many authoring apps can make use of them.
What format to rip my DVDs to my computer?
By SirMoby in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2011, 20:07 -
Newbie needs advice on burning DVDs in 5.1 format
By mcronix in forum Authoring (DVD)Replies: 2Last Post: 16th Sep 2010, 07:05 -
Help with playback on DVD player with burned DVDs (Codec and format)
By enjikari in forum Newbie / General discussionsReplies: 1Last Post: 28th Sep 2008, 02:33 -
Does iDVD make standard format DVDs (file structure-wise?)
By Scav2003 in forum MacReplies: 2Last Post: 5th Nov 2007, 01:11 -
ADVICE NEEDED... as of today, what is BEST vid format to convert DVDs???
By carapalida in forum Video ConversionReplies: 4Last Post: 7th Oct 2007, 16:39
