It says there are bugs with the newest sizzle and 10.3. Will this be a problem?
Results 31 to 34 of 34
the bugs are
1. the menu may not load in DVD Player.
they do load in VLC and also on all the standalone dvd players i have tested
2. you may get unsynced / unplayable results if you choose a muxed .mpeg or .vob. Work around: Use demuxed ones like I said above
3. Some people are unable to create new documents. Solution: try it and hope you are not one of those people. :P
so far I have not experienced anything other than that. -
I tried galactica's idea and the quality is absolutly horrible. I tried pixel's idea and got this error: An error occured while (re-)multiplexing. Make sure all program streams have DVD NAV sectors.
Help? -
My first method? sure it was 10 gigs down to 4! over 50% reduction it should look like mud
please try the sizzle 0.5 tutorial i posted above
just use one of the .m2v and .mp2 sets so you can see how it works and get results fast.
use VLC not dvd player to view your results
i bet you will be pleasently surprised with this.
Problem: Final Cut Pro, taking a 24p HD Blu-Ray and making a DVD with Toast
By apollo1980 in forum Authoring (DVD)Replies: 1Last Post: 22nd Apr 2010, 10:03 -
avi to dvd in toast 9
By levi747 in forum MacReplies: 4Last Post: 2nd May 2008, 22:43 -
Making a Toast "DVD Video" Disc
By albloom in forum MacReplies: 5Last Post: 22nd Apr 2008, 12:45 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 13:03 -
Making files for Toast 7
By MikeyGee1 in forum ffmpegX general discussionReplies: 7Last Post: 18th Jul 2007, 14:55
