I am using tempg dvd author ( latest registered version ), and I love it becuase it is so fricken simple. I really liked the simplicity of the menu making and all until recently when i started making my own animated menu's for the first time.
Is there a way to edit the Standard Menus that come with program?
Is there a similar software that is simple to use but has more menu capabilities?
Can you import menus made with other software into a setup with tempg dvd author and if so how?
thanks for your time !!!!
No. But you can use the menu wizard to style menus of your own (kinda).Is there a way to edit the Standard Menus that come with program?
As simple to use but with good, serviceable menus: not that I am aware of, but I am sure someone else here probably knows.Is there a similar software that is simple to use but has more menu capabilities?
As far as I know, no. It uses a proprietary menu structure during authoring.Can you import menus made with other software into a setup with tempg dvd author and if so how?
TMPGEnc DVD Author 2 questions
By siluet in forum Authoring (DVD)Replies: 15Last Post: 27th Apr 2009, 21:57 -
TMPGEnc DVD Author 3 (TDA) Questions
By Brent.M in forum Newbie / General discussionsReplies: 5Last Post: 11th Feb 2008, 00:34 -
Some questions on TMPGEnc DVD Author 3
By rock_king_my in forum Authoring (DVD)Replies: 4Last Post: 7th Dec 2007, 07:32 -
questions about using GUI for DVDauthor to author DVD
By jimdagys in forum Authoring (DVD)Replies: 8Last Post: 2nd Dec 2007, 20:08 -
GUI For DVD Author - A Couple of Questions
By deadwing in forum Authoring (DVD)Replies: 8Last Post: 6th Sep 2007, 02:25
