I've tried that little program that should disable ATI macrovision detection.
Result: no way.
Moreover, since then I have problems acquiring as I've described in another post, don't know if there's a connection between the two things but I guess it' so.
For my experience: don't install that program.
Results 1 to 11 of 11
I have used it and so have most of the people at http://www.rage3d.com forums. It worked for us!
Sorry it did not for you.
I've also used it.
I detects some (rare) macrovison signals, but seems to put a line in all captures, macrovison or not.
It doesn't work at all. -
I've used that little program and its worked perfectly for me. I use the ATI All-In-Wonder 128 Pro, since I've had this I've only had a macrovision detection once since i got it 2 months ago. I think this program differs between the different cards in the series. Also I have version MMC 7.1
I've had no problems at all with it. -
I capture from VCR and have no Macrovision. Before I got the program I could not capture my Disney tapes.
Now they capture no problem. So it does work for me.
I have a All In Wonder Radeon. And have used this program with MMC 7.0, 7.1 & 7.2
If it dont work for you thats tuff! But it does work for most of us. And if you want more proof go over to http://www.rage3d.com and ask in there forum. -
hey I didn't want to hurt anyone, just reporting my experience, with my ATI AIW 128 AGP under W2K (MMC 7.1) the program had no effect at all.
sorry. -
try this:
http://www.doom9.org/software2.htm#supportutils
hope you have more luck ...
Anyone Have Experience Converting MPEG2 to H.264 with an ATI Avivo Card?
By drstew in forum Video ConversionReplies: 3Last Post: 24th Jun 2010, 10:00 -
Disable HDMI audio
By JOHNINA in forum DVD & Blu-ray PlayersReplies: 5Last Post: 28th Feb 2010, 09:58 -
How to disable macrovision in Go Video DV1140
By wbsearch in forum Newbie / General discussionsReplies: 11Last Post: 17th Nov 2009, 22:10 -
Disable Forward
By modtec in forum Software PlayingReplies: 2Last Post: 27th Jan 2009, 11:46 -
Disable audio in Avidemux
By tuanvn.2007 in forum Video ConversionReplies: 1Last Post: 22nd Sep 2008, 10:15
