The MPEGPRO MVR is an MPEG capture card. You don't do any but the very slightest editing in MPEG. MPEG is a presentation format, not an editing format.
Editing is the reason you will want to capture in DV and be able to use all the fantastic software and hardware DV editing tools out there now. I'm talking about professional software/hardware like Avid Xpress Pro (with Mojo is crazy good), almost professional software like Premiere Pro, Media Studio Pro and Vegas and consumer software like Studio 9 or Video Studio. Most can deal with other formats like huffy, MJPEG, MPEG, etc., but they all work so much better with DV that it's not funny.
Here is an example: your shooting a new project on DV and editing in Premiere Pro. Now, you realize you also need to edit into this same project some analog Hi-8/SVHS/8mm/VHS from 9 -10 years ago. Do you want to capture this analog footage in as DV for seemless integration into your project? Or do you break out the old TV card, DC10+, DC30, or ATI to capture huffy, MJPEG, or GOD forbid MPEG2 and then have to render it to DV in software to go into the project? Unless you are insane, you want that footage put through a hardware DV converter to go into your project.
If all your doing is capturing a TV show or VHS movie with very light or no editing, then a consumer mpeg solution is good enough, but good enough for capping TV shows was not the point of this thread.
Results 31 to 36 of 36
I never quit trying new things and expanding knowledge.Originally Posted by ajc53
DV 4:1:1 sucks for conversion.Want my help? Ask here! (not via PM!)
Follow it all the way through to playing a DVD on TV: it is not very noticable. Matter of fact, I can't tell the difference. May be it is because camcorder VHS is inferior anyway.Originally Posted by lordsmurf
I will tell you what sucks!!!
Going over the "Top ten Do's and Don'ts to prevent DROPPED FRAMES and AUDIO SYNC problems", to see what I may have missed.
That is not a problem for me in DV conversion using the ADVC. -
So mracer, with all that said, if I want to capture from VHS and Hi8 as a direct copy to DVD as an archive, what would work best? Plextor Convertx or Canopus ADVC-100? Or another product? Quality is important as well as time and cost.
Now once I have the copies on DVD, am I correct in stating that I will need to recapture in order to edit? What equipment/software would be best keeping in mind that these are home projects.
Thanks again for your assistance. -
AuditSup, I'm sorry but I must defer any comments about the Plextor Convertx to someone who actually uses one. I do not want to make comments about equipment I have not had the chance to use myself.
My thoughts on your situation are this: if you don't need to edit, buy a standalone DVD recorder to make DVDs of your old tapes.
If you need to edit and want more control over your projects, I think the best solution for you would be a software package like Ulead Video Studio 8 or Pinnacle Studio 9, the ADVC-100, and a DVD+/-R /RW burner.
I 've used the ADVC-100 extensively and I'll be very happy to try and answer anything I can about it. In my experimentation and testing, I've used the NEC 2500a, Avid Xpress Pro, Avid Xpress DV 3.5, Media Studio Pro 7, Premiere Pro, Movie Factory 3DC, Studio 9, Encore, Video Studio 7, DC10+, BT878, Mainconcept 1.4.2, TMPGEnc 2.5, and TMPGEnc DVD Author.
When I work with analog material my work flow is usually something like this if I need to edit:
1. Capture analog through ADVC-100 using Studio 9.
2. Edit in Studio 9, Premiere Pro or Media Studio 7
3. transcode DV to DVD compliant MPEG2 in TMPGEnc 2.5
4. Author and burn DVD in TMPGEnc DVD Author
Or if I don't need to edit:
1. Capture from ADVC-100 straight to MPEG2 using Mainconcept 1.4.2
2. Author and burn DVD in TMPGEnc DVD Author -
Would you happen to know of any good images that show MPEG 4:2:0 standard? This is a topic of great interest to me right now.Originally Posted by vhelpWant my help? Ask here! (not via PM!)
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 19:26 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
Capturing with Canopus ADVC
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 29th Nov 2009, 22:55 -
Canopus ADVC-55 vs. ADVC-110
By bcags7 in forum Capturing and VCRReplies: 4Last Post: 2nd Nov 2008, 16:15 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 09:19
