I have been giving Dvd Decrypter a try, based on comments on this forum.
But, Dvd Decrypter only burns my 4X Ritek DVD-R at 2.1 with the setting on max or 2X /4X . Am I missing a setting or something? The DVD burns OK otherwise.
The 2.1 would be my rewrite speed, but I’m not using that.
I have been burning OK with TDA. It burns in about 12 minutes, which should be at 4X. I would not know it though by the status display, because it never works.
Results 1 to 9 of 9
Which version are you using of DVD Decrypter ?
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Have you burned this type of media with another program and it burns at a higher speed ?
Best Regards,
Sefy Levy,
Then this might be a bug within DVD Decrypter, have you tried contacting it's author ? he is a great guy and very helpful! and might solve the problem for you quickly
Best Regards,
Sefy Levy,
Thanks, I will do that tonight.
It's not a big deal, though, because TMPGEnc DVD Author does just fine. Thats the program I’m usually in when it’s time to burn. The lacking of a good status indicator is not important, because it's only 12 minutes and done.
For that matter, I never had a problem with Roxio DVD Builder, for burning an existing ISO. The program sucks otherwise. -
OOPS My Bad
I went back and looked closer, and I did not select 2 - 4X but rather 2.4.
My media shows up as 2X 4X and I misread the setting, thus my error.
When I selected 4X , presto, 12 minute burn. I don't it burned 4X, though, when I selected "Max", but who cares.
Great program. Had not used it much yet, as I am neck deep in home movie conversions.
But when I do I plan on making a donation. -
I'm sure the Author of DVD Decryptor will appriciate it, tell him Sefy send you
Best Regards,
Sefy Levy,
burning a dvd with dvd decrypter
By shashgo in forum Authoring (DVD)Replies: 1Last Post: 29th Dec 2008, 18:34 -
question about DVD HD Fab Decrypter/Burning
By Bamahusker in forum DVD RippingReplies: 22Last Post: 19th Nov 2007, 12:33 -
reauthoring TDA video in TDA throws audio off
By spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 19:04 -
Burning speeds and DVD Decrypter...
By Nilfennasion in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2007, 05:32 -
Problem burning to Verbatim DVD+R DL with DVD Decrypter
By spyder67 in forum Authoring (DVD)Replies: 6Last Post: 14th May 2007, 18:49
