Hi,
I am trying to capture my VHS tapes in DV-format using my ATI AWI 9800SE card. If have tried using both VirtualDub 1.5.10 and ATI's MMC8.8 together with the Panasonic DV codec.
When I select this codec in MMC, it does not record anything; I am also not able to change the setting of the codec in MMC. (An additional problem with MMC is that I cannot select the screen format 720x576)
When I use VirtualDub, I see the Panasonic DV codec in the list of codecs. However, when I select ''WDM Image Capture'' (the graphics card), the DV codec (and also some other codecs) has disappeared from the list. I also tried the MainConcept DV codec together with VirtualDub, but this resulted in a black image with some colored squares.
Who can help me with capturing DV with the ATI AIW 9800SE card? Thanks in advance!
Results 1 to 1 of 1
ATI AIW 9800 Pro worst capture card ever?
By veedeo in forum Capturing and VCRReplies: 15Last Post: 1st Jan 2011, 19:41 -
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 12:26 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 06:11 -
ATI AIW X800GT - ANY capture software besides MMC?
By nbarzgar in forum Capturing and VCRReplies: 23Last Post: 18th Nov 2007, 02:24 -
Problems with Pal-60 capture using ATI AIW 2006 PCI express Radion X1300
By DB83 in forum Capturing and VCRReplies: 2Last Post: 6th Aug 2007, 17:49
