Just a quick question...
Im trying to convert a DIVX AVI file to DVD WITH the post-processing effects that the Divx codec provides. I've tried saving the AVI in VirtualDubMod using Full-Processing mode and HuffyUV compression. This creates a massive AVI file that actually includes the Post processing effects that Divx utilises when playing a film using the Divx codec. So I then try and convert my new AVI with AVI2DVD but unfortuately it only converts the first five minutes or so and then stops. Is there any reason for this? Ive checked the original AVI for errors previously and there are non and I have also successfully converted the original. Is there a maximum file size CCE or AVI2DVD can take or something?
Any ideas or an easier way to attain a DVD version of a Divx file using CCE and AVI2DVD with the Divx post-processing effects?
Thanks in advance for any help provided!
