Hi, i've rendered a tga sequence with 3ds max with a sky background,
my problem is that when i import the tgas to adobe premiere,
it doesn't show the sky, it is interpreting the alpha channel,
how can i tell premiere to ignore the alpha channel?
please help, urgent![]()
Thank you.
Right-click on the tga clip and select "Set Transparency". Choose "Alpha Chanel" from the list of transparencies. That will make the Alpha Chanel transparent so that you will see the clip below it.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Thanks for your answer, but i don't see a set transparency option in the
right click menu, or anywhere else, (i'm using adobe premiere pro 7),
is there another way?
Thank you. -
premiere pro sets the alpha transparancy automatically. you can to going into the video effects folder, and play around with the keys there.
It's in the effects palette.
In order to be transparent you'll need the files that you want to have transparency in video track 2 or above and your cloud background in video track 1.
Problems with Alpha Channel
By CKyle in forum Newbie / General discussionsReplies: 3Last Post: 9th Mar 2011, 16:02 -
Good compromised codec with alpha channel
By elmuz in forum EditingReplies: 6Last Post: 17th Sep 2010, 10:07 -
VP6a encoding / video with alpha channel
By GRUMBLE in forum Video ConversionReplies: 2Last Post: 26th Aug 2010, 04:08 -
where can i get 3D Clips with Alpha Channel for wedding or romanic scene
By DigitalGuard in forum Newbie / General discussionsReplies: 0Last Post: 6th Aug 2007, 11:14 -
Video Clips with Alpha Channel
By MonaW in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2007, 12:31
