  1. when i try to load a .d2v in tmpgenc i get this error message....
    i made sure the dvd2avi.vfp was in the same directory as tmpgenc....any ideas
    Massimo N. Aldorasi
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    Have you tried raising the priority of the dvd2avi plugin in Options>Environmental Settings>VFAPI Plugin?
  3. yea i raised it to like...10....should i put that higher?
    Massimo N. Aldorasi
  4. Member teegee420's Avatar
    Dec 2003
    Southern California
    Don't think that will help. I see that your are working with a kvcd mpeg. Probably mpeg-1. I believe Dvd2avi only works with mpeg-2.
  5. sounds reasonable...i guess......just tried it out and the same error message showed up...
    Massimo N. Aldorasi
  6. Member teegee420's Avatar
    Dec 2003
    Southern California
    What was your reason for using Dvd2avi? Maybe you can get the same result with another program.
