copied a dvd onto my hard drive using dvd decrypter. i'm left with the main ifo and vob files and was wondering what was the best prog to use to convert them to divx.
Results 1 to 16 of 16
You can use AutoGK if you're a beginner, this is an outstanding package. If you're up to more complicated settings, Gordian Knot (AutoGK's big brother) is my personal favourite.
If you're looking for something really simple then Dr. DivX is your man.
If you click the red "AutoGK" in the first line (or Dr. DivX) and look below the tool description, all the relevant guides are listed for you. Please use the guides, and if you get stuck have a search of the forums. Ten minutes can yield a lot of information!
If you need any further assistance if guides/searching fails, just post up and I'm sure you'll be sorted out.
Cobra -
This is the only trouble with asking a "What's best?" question - everyone has their own personal favourites. You don't really get many "good" answers.
As jarvis1781 says, Vidomi is another good one, comparable to AutoGK. As for DVD2AVI, I've never actually used it for converting to AVI but the name implies that it does the job. As jimmalenko says, it's probably for the more advanced user.
Cobra -
For the bog standard simple do nothing, auto gk, Dr Divx is also a good noob prog also.
rite. ripped the main movie files from 'some like it hot' from dvd onto my hard drive. i then used autogk to try to convert it. once it had got finished i got left with this.
http://members.fortunecity.co.uk/joeyjoejnr/somelikeithot.JPG
should it not be in divx? whats wrong? -
you do have to name the output file.. it will be in the parent directory (go up one). A tad more looking about would have found it
And the log file details all stepsCorned beef is now made to a higher standard than at any time in history.
joeyjoejnr,
You haven't read the guide for AutoGK.
http://www.divx-digest.com/articles/autogk.html
Step 4 - you can't miss it.
Please read the guide, follow it and post back with specific questions if you have difficulty. Using the guide will save you time anyway!
Cobra -
i done step 4. i set it to 700MB. i did name the file as well (u can see i named it some.like.it.hot. the only problem is i got loads of files when i only wanted 1 avi file
Originally Posted by RabidDog
The encoder can't be working away for ages and not have produced anything!It has to be there.
Cobra
(Edited once to fix quote)
ripping and converting
By bigmacsexgod in forum DVD RippingReplies: 1Last Post: 26th Dec 2009, 11:40 -
Easiest and fastest ripping prog?
By Valioser in forum DVD RippingReplies: 1Last Post: 5th Mar 2009, 17:57 -
Ripping And Converting
By Lennoxtown in forum Video ConversionReplies: 4Last Post: 17th May 2008, 04:39 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 23rd Feb 2008, 23:35 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 05:48
